Need advice on 383 G-body build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-29-2013, 07:30 AM
Flat top pistons, 2 eyebrows, .025 down the hole (light clean up on the deck) .041 felpro head gaskets and a 3 core radiator. Would rattle the valves if I got a hold of some not so good gas. Had to run it a little rich or it would complain!!
  #17 (permalink)
Old 04-29-2013, 07:44 AM
This was with the Dart 190 alum. heads 2.05 int. 1.6exh. 72cc Found some old notes!!!!
  #18 (permalink)
Old 04-29-2013, 07:49 AM
Manley valves .100 longer and .100 longer pushrods. Like I said...found some old notes!!!
  #19 (permalink)
Old 04-29-2013, 08:07 AM
Originally Posted by techinspector1 View Post
Assuming a 9cc gasket and zero piston deck height, I get 10.22:1 SCR
When you guys do this stuff, try to show us all the tech data that's available, like the gasket displacement, piston deck height displacement and some info about the cam that we can use to make sense out of the whole mess.......please........I had to hunt up the timing card......
Isky Timing Chart
I like this cam better....
Isky Timing Chart
With 1.6 rockers, the valve lift is 0.565"/0.587"
The flow numbers I found for the heads used a 4.155" intake pipe and that pysses me off a little bit. All of us know that a larger pipe will result in higher numbers, but if you're bolting the heads onto a 4.030" bore block, then the numbers are bogus. I factored their numbers by 0.95 and here are the results.....
0.200...135...95
0.300...194...136
0.400...237...166
0.500...267...184
0.600...270...194
0.700...273...202
RPM.....HP.....TQ
2000...145....380
2500...184....387
3000...235....411
3500...299....449
4000...362....475
4500...420....490
5000...469....493
5500...491....469
6000...505....442
6500...483....390
Peak volumetric efficiency 99.7% @5000 rpm's
Peak BMEP 194.1 lbs @5000 rpm's
Give up 25 hp with the shorter cam.
That cam was actually my first choice but since I am using the factory roller lifter setup my concern with exceeding .354 lobe lift was pushing the lifter below the dogbone. Am I wrong in that line of thinking? If I can get away with the bigger cam I certainly would.
  #20 (permalink)
Old 04-29-2013, 08:47 AM
Raptorus1, sounds like it is decision time. Stick with the oem rollers and limit yourself with lift and cam choice or can all that and go aftermarket. Not that this is a bad thing but it is what it is with what you choose to work with.
  #21 (permalink)
Old 04-29-2013, 09:35 AM
Banned
switching to overkill mode will help you get a quicker et, but on the street durability matters.
I'd back off on the lift for a durability and maintenance stand point. .500" lift or a little more will be more than adequate for your goals, I'd limit it to .550" or below especially with stud mount rockers if you want a low maintenance engine.
I used to be a guy that chased after aggressive lift too, as it will get you a few more ponies, now I choose to give up a few ponies to save some bucks and allow me more time behind the wheel.
You have 383ci and pretty good heads, your power goals are not that hard to meet and still have GREAT drive-ability and durability. You can shoot for an extra 50hp but you'll have to start trading durability and/or cost.
Your original plan looks to be a great street engine, my only change would be to run EFI, but that's a whole separate subject. (you'd be surprised how much nicer EFI can make a car even if it adds 0hp, there's so much more to an engine than hp and EFI really makes that obvious)
  #22 (permalink)
Old 04-29-2013, 09:43 AM
I agree that EFI is the way to go but most people have a hard enough time building an engine sensibly much less mapping fuel management curves that work. Especially something a little warmed over. Timing curves are hard enough for some to get correct. I say this not to be an ***** but just reality from my experience with many hot rodders.
  #23 (permalink)
Old 04-29-2013, 09:52 AM
Banned
I would argue that tuning EFI and electronic timing is WAY WAY WAY easier than messing with jets or a mechanical dizzy, and I grew up on carbs and distributors.
datalog and punch a few keys... you can literally tune your car while wearing a suit on your way to Sunday service- try that with a carb and a distributor.
The Following User Says Thank You to ap72 For This Useful Post:
64nailhead (04-29-2013)
  #24 (permalink)
Old 04-29-2013, 09:57 AM
And that's the problem..constantly messin' with it looking for something. No argument whatsoever just seen it happen too many times.
  #25 (permalink)
Old 04-29-2013, 10:54 AM
Banned
Watching all those things isn't a bad thing, it's helped me dial in my air temp correction factor and small things like that. You just need to understand that as you go required changes become smaller and smaller.
  #26 (permalink)
Old 04-29-2013, 11:08 AM
I agree about the EFI been there and loved it. I want to stay with the carb on this one. Like I said before this is just my weekend cruiser. Just want something nice with the power I need to keep the children in the ricers off my nerves lol. My 6al and billet dist is about as exotic as this car will get. Have a 4th gen camaro I will be going all out on soon enough.
  #27 (permalink)
Old 04-29-2013, 08:05 PM
vinniekq2's Avatar
lots of fast ricers out there.They seem to have a lot of money to burn
  #28 (permalink)
Old 04-29-2013, 08:41 PM
Banned
It's not as expensive as you think, ebay turbo, e85, and a set of the biggest injectors you can find, maybe a fuel pump too.
Turbo imports are the new cheap way to go fast. Classic muscle is too expensive.
  #29 (permalink)
Old 05-04-2013, 07:01 PM
Looks like fate made that decision for me today just discovered three bad lifters so im gonna take that as a sign and pony up for a retrofit set and use my other block. And i have this retro roller cam already which should do fine and be a little more radical.
Lunati cam Cam Spec Card :: Lunati Power
  #30 (permalink)
Old 05-04-2013, 07:12 PM
vinniekq2's Avatar
you can use that Lunati cam,its ok
383 stroker or 355 build advice please Chad. Hotrodding Basics 22 03-01-2013 11:12 PM
Possible 383 build, need a little Insight /Advice all4sr's Engine 18 02-19-2013 01:33 PM
Need advice on a 383 build Sohcnick Engine 8 06-25-2012 01:14 PM
383 SBC Build advice Andy Sweeney Engine 5 10-13-2011 05:25 PM
need advice on 383 build up mxbadboy03 Engine 4 10-12-2007 08:33 PM
