need advice on 49 Caddy suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 09:01 AM
I have a 49 Caddy fastback and building it as a daily driver with a sb chev. I would like to install modern front brakes and anti dive suspension but Fatman only company making frame clip and concerned about negative comments about under engineering and breaking A arms. Anyone have good idea?
Old 07-26-2006, 11:23 AM
Paddyboyy's Avatar
73-87 Chevy truck front suspension just unbolts from the frame. 34 inches wide. No frame cutting. Worth a peek.
Old 07-26-2006, 11:31 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Studu on the various kinds of front ends available..Camaro Nova clips can work on that car I believe..Lots of options are available..
Sam
Old 07-27-2006, 07:24 PM
Is Camero / Nova frame clip strong enough - Caddy over 4,000lbs even with chevy engine in it. Anybody do one of these mods????
Old 07-28-2006, 12:47 AM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
Jst dont get lowering springs. They will sag a bit more than a Camaro or Nova, but not too bad. I have a Camaro clip on my F100, and it has a 514 in it. The suspension sagged maybe 1" at the most with the fully dressed motor installed. And thats a heavy motor. Comparable to the Caddy 500, heavier than the 429 or what it was that came in most Caddys.
Old 07-28-2006, 04:04 AM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Hey! I object...
The Caddy 368-500 motors weigh only 50# more than a small chevy does.
Not bad for almost double the displacement, and more than double the torque. When I was still driving the '28 around, I did a Caddy swap after the original Jeep 258 crapped out. It sagged the front MORE than the Caddy did, stoopid inline 6 with half the power...
The Chevy pickup 2wd frontend is a good idea, plenty strong and parts readily available.
The frontend of the Kustomsledd only needs 65 PSI in the airsprings to top them out, with a 472 sitting directly over the spring mounts, and that's with the smallish 2600# bags, that I had to use to fit inside the lower control arms...
49 merc front suspension upgrade powerrodsmike Suspension - Brakes - Steering 6 08-05-2005 09:20 AM
'49 Ford Suspension CHUCK CRUSE Suspension - Brakes - Steering 2 07-17-2005 12:14 PM
Air Suspension on 49 Chevy Truck BigMac Suspension - Brakes - Steering 7 10-28-2003 01:51 PM
air ride suspension on 49 Dodge coupe brettw Suspension - Brakes - Steering 5 08-14-2003 11:09 AM
Need advice on caddy 500 jeff of nc Engine 4 02-18-2003 04:40 PM
