need advice about HOK dry pearls - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2010, 06:18 AM
Hey everyone,
I'm gonna be painting my 00 civic with a dry pearl over HOK white base coat. I was wonder if I sould spray the dry pearl in my clear coat or what. I'm either getting blueberry, blue green, or sea green over the white like I said. I'm trying to go for a light blue or green.
Please helpp!
And if you can could you also tell me how much of each stuff I need so I don't buy more than enough. I'm only spraying my car and the lip of my rims. If need be I'll post a picture.
Old 01-16-2010, 08:44 AM
deadbodyman's Avatar
Wiki Edits: 11
I use a intermix clear (I think its called) its like a clear base coat that dries quick when everything is even and looks right then use clear....its like a tri coat system.When you add the pearls to the clear and you get a run ,the pearls run too and theres no good way to fix it.The amount of pearl is up to you but to much will change the color your tring to get...
Old 01-16-2010, 09:17 AM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
Intermix clear gives the pearl a body so the pearl flakes are spread out evenly, I also would use that. You can mix it in your clear but you can have problems like Deadbodyman said but if you do, put another 2 coats of clear, no Pearl over top.
Old 01-17-2010, 01:25 AM
Good advice, also try and measure out how many grams of pearl you use VS the amount of intermix clear, then it's just a matter of remembering how many intermix coats you put on if you ever needed to repair a panel.
A little dry pearl goes a long ways, you might want to make some test panels to spray to perfect the amount, I would start off with a dash per pint of intermix, it really depends if you want a colored shimmer in the sun or have a heavy pearl effect.
HOK makes premixed pearl coats that lay out like base, that will go over white base nicely.
It's nice when you have to repaint a panel or two, I just redid a few damaged panels, ground effects, and rim inserts on this van with perfect color match, HOK Tangelo orange over HOK white
ID:	43268   Click image for larger version
Old 01-17-2010, 01:42 PM
Official Solventologist
Intercoat clear is the way to go. It makes the pearl so much easier to lay down even. PPG's DBC-500, HOK's SG-100, or these guys products are all good choices:
http://stores.ebay.com/TheCoatingSto...subZ1553781015
They make some nice pearls also. As far as pearls go I would recommend a xyrellic pearl escpecially over a white base. The xyrellic pearls will give you a nice clean white pearl effect without that dingy yellow you see sometimes on white tri-coats.
You can find the xyrellic pearls here.
http://stores.ebay.com/TheCoatingSto...subZ1553955015
They also have it in a premixed form already mixed with basecoat (intercoat clear).
http://stores.ebay.com/TheCoatingSto...+pearl+midcoat
Add shows only the white pearl xyrellic mix but they will mix whatever pearl you want in.
Good luck!
What Brand Epoxy Primer under HOK Base? Craig legacy Body - Exterior 4 03-30-2009 05:32 PM
newbie advice davemad Introduce Yourself 1 01-15-2009 11:16 PM
I couldn't leave well enough alone!! Need Pro's advice Corpsegrinder Body - Exterior 5 07-09-2008 04:46 PM
Need advice on HOK Ulta-Micro Metal Flake!! texastomeh Body - Exterior 0 05-20-2008 09:11 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 01:36 AM
