Need advice and all input on carb jetting - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-30-2010, 09:09 PM
Yeah I know you can't go by that for a test. I did not see much difference between the silver spring or the purple one. After all this is in a s10 which it does not take much to get it going anyways. I have a quick change on it so I will give a yellow one a try and see what it does. My carb is running a little better so far will have to do some more driving to see how my plugs are going to do. I might have to get another set and am also going to see about getting a good set of aluminum valve covers with good baffles in them from summit so my pcv can quit soaking up some oil.
Thanks again
Eric
If you do not want to register, fill this field only and the name will be used as user name for your post.
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
