Need advice with Blazer Interior - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2012, 06:54 PM
oldcpecdr's Avatar
Hey All
After 7 years in the Exterior Forum and lots of browsing I FINALLY got the exterior of my son's Blazer finished.... with LOTS of help from everyone, and the second time I did it it really FINALLY looks good !!!!!
Well except for the inside.... and I am sure if he were still here.... we would be looking at a full custom...but since its me finishing it now and my interior skills are to say the least limited.... its time to learn.....
Like MartinSR I too have a 5 year old pre-formed carpet kit (ACC)... any more tips on getting a good install ? Its a column shift two door so looks fairly straight forward.... I also have a new headliner kit, preformed polyvinyl liner with the cloth already installed... anyone done one of those ? Looks easy but always better to ask.... I have two mint front power seats in charcoal and will probably need to ask questions as I go about recovering the back seat to match....
Any benefit to using one of the sound deadener materials that I see out there, is Dyno Mat or one of its clones worth putting under the headliner, carpet, door panels ? Not going to be an audio roller, just an everyday Blazer to drive and enjoy as often as I can in memory of my son, any thoughts are appreciated,
Thanks.............. Mike B
Name:	Blazer NEw 41.jpg
Old 04-10-2012, 07:28 PM
DanTwoLakes's Avatar
Wiki Edits: 22
It would help to know what year vehicle we're talking about.
Old 04-10-2012, 10:00 PM
oldcpecdr's Avatar
1990 S10 Blazer
A 1990 S10 Blazer.....
Had to go look !!!!!!!!
Mike B
Old 04-11-2012, 07:09 AM
Wiki Edits: 22
The carpet is very straightforward, just take your time and keep smoothing it out until it conforms to the floor. Anything you add as a sound deadener will be an improvement, no matter what you use. Just remember that you don't have to cover every square inch to make an improvement. The headliner should be a board of some kind, and it should have trim pieces around the edges to hold it up. The trim pieces come off first, obviously. Here's a link to a thread that may help you with that: CLICK HERE
Old 05-06-2012, 07:39 PM
oldcpecdr's Avatar
the headliner project
Started the headliner install today..I'l try and get pics as I get into this project.
The headliner arrived a few months ago... I ordered Dynamat Extreme on Amazon and the pricing appears to be the best available. The Dynamat cuts easily with razor knife and a straight edge... and a scissors for any curved areas....I used a small roller, some plastic putty knives, and a filler spreader as tools for tucking the edges under some of the Blazer roof edges.. pre-heating with the heat gun helped a LOT..... but be careful not to blister any paint on the roof... I thought of that as I burned my finger on the hot aluminum foil facing.... no paint damage !!!! Halfway done and looking ok....
I need to do a little more research and see if that big flat roof needs more sound proofing..... probably be a week before I can get back at it but nice to make some progress !!!! Mike B
Name:	Blazer Headliner 1 - Copy.JPG
ID:	65218   Click image for larger version
Name:	Blazer Headliner 3.JPG
ID:	65219   Click image for larger version
Name:	Blazer Headliner 6.JPG
ID:	65220   Click image for larger version
Name:	Blazer Headliner 7.JPG
Old 05-07-2012, 08:28 PM
oldcpecdr's Avatar
Easier than paint !!!!
Took a few hours tonight and finished the Dynamat extreme install on the roof...a LOT easier than the 7 years it took to get the paint right !!!! So roof panel is 99 % covered..... I probably should take it for a ride and check out the sound level......
Has anyone used the Dynaliner on top of the Dynamat Extreme ? Worth the effort for an occasional daily driver ? Or is it overkill....
So depending on that decision, headliner in next week...
Mike B
Name:	Blazer DynaMat 10.JPG
Old 05-08-2012, 12:38 AM
Wiki Edits: 22
Completely covering the entire roof was overkill, adding more to what you already did is a waste of time and money.
Old 08-28-2012, 12:19 PM
oldcpecdr's Avatar
Carpet In
So I already had the dynamat so went for overkill on the floor too.. the Carpet Kit fit amazingy well once I got over the fear of trimming it...ACC did a nice job manufacturing the carpet.... the mold press they use leaves pretty obvious lines on the backing material... cutting along that line and leaving about a half inch extra REALLY made the job easy. I used a pick to locate the seat bolt holes and then a hollow leather punch made it EASY to punch the holes without tearing up the carpet at all.. slid a small square of plywood about 6" x 6" and used the awl as the center mark... I used scissors to trim the rug found it more precise than a razor knife for the curves up under the dash. Time consuming but a worthwhile project for anyone with some patience...
Next up... the headliner this weekend...
Name:	blazer seats new1.JPG
ID:	67645   Click image for larger version
Name:	Blazer dynamat.jpg
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 03:21 PM
Interior metal floor edge against interior body 55paneltrk. Body - Exterior 1 09-12-2011 02:00 PM
Chevy blazer finished interior pics Wrapped Up Interiors Interior 7 07-12-2011 02:19 AM
Need Advice On Touching Up Worn Interior Silver Paint Blood Red Vette Interior 5 11-05-2010 07:16 AM
