Need advice on block sanding please - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2009, 11:46 PM
This is my first time block sanding. I've done a lot of research , but most of the information I found is on sanding filler for small areas, not entire panels like this.
Am I taking down too much filler? I'm currently using 80 grit.
At what point do I switch to 150 or 220 grit?
I started on the upper right corner and working my way down, then to the left. The lower curve area is tough to reach. I think i need a more flexible block here.
I really appreciate your thoughts.
Old 07-21-2009, 01:21 AM
JeffB's Avatar
Tech on block sanding
Try this website: www.jefflilly.com click on restoration there is lots of DIY info there.
Old 07-21-2009, 08:48 AM
302 Z28's Avatar
From your picture it looks as though you already have the proper sanding blocks so I will not go into that. You will use 80 or even 36 grit to first knock down the new filler. Once you no longer see un-sanded filler then switch to 180. You also need some type of guide coat to indicate low spots. Some will advocate the use of a cheap spray bomb of contrasting color paint to do this. What I have found works even better than that is 3M's "Guide Coat". It is a black powder that easily indicates any low spots. There is no paint to sand away and the powder can even be used wet. A tub of it will last through 5 or 6 cars, so it goes a long way.
Vince
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
K Block sanding blocks AntnyL Body - Exterior 0 09-01-2008 12:06 PM
Block Sanding Man586 Body - Exterior 2 07-27-2004 08:02 PM
Sanding Block Man586 Introduce Yourself 2 07-27-2004 07:16 PM
need advice bad! 400 small block irocan Engine 0 02-10-2002 04:17 AM
