need advice ,,brake problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 01:22 PM
Last journal entry: dash mods
i have a 38 chevy m 2 dr sedan, I have a 7''dual diaphram power booster , with a 1'' bore MC, cowl monted. The disc brakes are TCI kit camaro, the rear are common 10 bolt drums. I lengthened an S 10 pedal. The brakes seem fine if I am driving and not stomping them. The car slows like my daily driver does. It stops Ok if i drive normal, a light brake to stopping. If I want to stop fast, no way. I can't lock up the wheels except on gravel or sand. The car just will not stop fast. What am I missing or lacking?
Old 01-11-2012, 01:54 PM
35terraplane's Avatar
Brakes
I have always used a bigger bore mc on my cars and have no trouble. do you have a leak anywhere, do you have a p-valve on it and is it set right.
Do you have a mc that is for disc, drum setup.
Bob
Old 01-11-2012, 02:08 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
I think the M.C. is too small, but I'm no expert
anyone else have any info?
Old 01-11-2012, 03:56 PM
Brakes
Bob
Old 01-11-2012, 07:25 PM
Cape Cod Bob's Avatar
Visit MP Brakes here http://www.mpbrakes.com/technical-su...-cylinders.cfm and scroll down to brake pedal ratios and see if your extenede pedal com plies.
Old 01-12-2012, 11:40 AM
Post
How did my post get on there twice, it wasn't there when Matt posted.
Bob
Old 01-12-2012, 11:03 PM
& matts38chev
did you come up with anything?
Old 01-13-2012, 07:39 AM
Frisco's Avatar
Glad To Be Here
The 7"dual diaphragm aftermarket booster needs a 1 1/8" bore master cylinder and the pedal ratio should be around 4:1 to function well.
Lengthening your brake pedal more than likely increased the pedal ratio to one that is greater than the 4:1 needed. This will cause you to 'run out of pedal travel' and thus no brakes.
The 1" bore master cylinder will work best without the power assist and a pedal ratio of 6:1 or 7:1.
Brake booster advice 1937MoPar Suspension - Brakes - Steering 1 09-26-2011 11:13 AM
Brake Rotor advice please kieferrestoration Suspension - Brakes - Steering 2 04-05-2010 07:47 PM
redoing my brake setup, need advice TheCiscoKid Suspension - Brakes - Steering 7 05-25-2009 02:22 AM
brake line advice please. S10V8 UK Suspension - Brakes - Steering 4 04-17-2009 09:50 AM
Need Advice: Which Brake Setup to Buy horvath Suspension - Brakes - Steering 5 08-27-2005 07:41 AM
