Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Advice: Which Brake Setup to Buy
Old 08-26-2005, 07:04 PM
horvath's Avatar
horvath horvath is offline
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Originally Posted by 66GMC
When you install new pads, you have to push the piston back in it's bore until the new pads clear the rotor. The way that I do that is to loosen the bleeder screw, and compress the piston back into the caliper using a C-clamp.
Thanks, Don
We did that, but the new rotors are too thick and the outboard pads won't clear the rotor - by 1/8th-inch ... the only solution I can think of is to shave the brake pad down and I'm hoping for a better solution than that.
I called JEG'S and talked to a tech there and he said a lot of times new rotors, being made overseas, are milled too thick and this is becoming a common problem!
What to do?
The new pads fit okay on my old rotors, but now my pedal is spungy (mushy) and I'd hate to see what would happen if I had to stop short!
Alan
54 Chevy Pickup
