Need advice on Edlebrock 600 cfm problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2006, 11:43 AM
Hi. got a minor problem on my Edle 600. When I go around a left hand corner at an intersection the carb seems to cut out then it picks back up when I straighten out. I dumped a bunch of drygas in the tank thinking I might have water in the float bowl. It didn't seem to help. I haven't got around to pulling the top yet, thought maybe someone might have some ideas to mull over first.
Thanks
Moon
Old 06-15-2006, 12:38 PM
Last journal entry: PICTURE TEST
Carb
I would say the float level is set to high, but you need to remove the top to set/check it..
Keith
Old 06-15-2006, 07:53 PM
float level
Definitely check the float level. My carb would do the same thing (die out). I would hammer the gas and then slow down rapidly and the gas was overflowing in the carb. Very easy fix. Let me know if you need the specs for the float level, I can find my instruction manual.
Old 06-16-2006, 03:52 AM
gazrnr's Avatar
Also check your fuel pressure. When I was running a 1406 it needed a steady 6 PSI. Once it was setup for my car it ran consistently good all the time. I swaped it out for a Jet Quadrajet Stage 2 carb that also needs 6 PSI fuel pressure. Good luck
Engine stalling problem JamesRS Engine 3 01-30-2006 11:22 AM
1994 Saturn Transmision Problem dmg53 Transmission - Rearend 4 01-18-2006 06:59 PM
Edlebrock Carbeurator Problem EazyDuzIt102 Engine 5 04-20-2004 11:24 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
