Need advice on fuel pump selection. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2005, 06:33 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Question is....... Can a quality mechanical fuel pump safley and reliably supply enough fuel to support a small block chev Making approx 450 hp? Thanks for any replies!
Old 01-07-2005, 07:18 PM
DoubleVision's Avatar
I don`t see why not, as long as the line is big enough, along with a high flow filter.
Old 01-07-2005, 08:45 PM
We have used mechanical fuel pumps by Holley, Edelbrock and Carter on motors making well over 450 HP for years. NASCAR even uses mechanical pumps.
Old 01-07-2005, 09:03 PM
Bowtie or Die!
Car has 3/8 line and tank unit.
Old 01-08-2005, 09:34 AM
fuel pump
yes carter makes a fuel pump that will give you the flow and psi you are looking for and moroso has a lite weight push rod i used a speedway pump on my car that was running 11.50 at 118 mph and had no problems we estimated it had about 550 horse
