need advice on heat warped roof. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-16-2010, 05:21 AM
deadbodyman's Avatar
Wiki Edits: 11
As the old saying goes: when in doubt ,leave it out...
how about making a convertable...
  #17 (permalink)
Old 09-04-2010, 07:31 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Welding in just a patch would be a problem, the welding heat distorts thin unsupported steel. You'd have to cut the entire roof panel out and replace it.
If you really wanted to fix it easy, cut the affected area out and epoxy sheet metal over it, or use urethane panel adhesive. Heck, good silicone adhesive caulk would hole it in place and seal it -- there is no stress in the roof panel.
Then have a vinyl roof installed. I don't care much for vinyl roofs, but we're talking about a garage kept car, not a driver that will be out in the sun all the time.
68 Chevelles are hard to find! You can get a new dash from a parts car, even a four door. The firewall may have some distortion, but not likely since it is well braced and stressed.
Roof Cutting/Grafting Options sparkydog Body - Exterior 7 12-28-2009 08:54 AM
underhood heat management slow ride Engine 15 04-22-2009 03:15 AM
here are some pics of progress on the roof atichargr Body - Exterior 0 04-12-2009 03:59 PM
need help with my roof atichargr Body - Exterior 2 12-31-2008 12:38 PM
Roof Panel Install Advice Scode68 Body - Exterior 4 10-08-2008 02:29 PM
