Need Advice on HP - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2006, 08:54 AM
rac43's Avatar
Need Advice on HP
I know there have been a lot of post about "How Much HP DO I Have" so here I am. This 350 is in a 23 T-Bucket and can anyone help me with what the crank HP may be? Major engine rebuild done!
76 350, 2 bolt main
Pistons,forged flat top .030" Speed-Pro with moly rings
882 Chevy heads with 2.02 intakes and 1.625 exhaust valves.
Cam, 222/222 at 0.50 GM 3896962 Hyd. Flat Tappet
HEI ignition
69 Corvette crank, ground .10 both rods and mains
Edelbrock TM-1 intake, single plane, Edelbrock 650 Thunder square bore
Built turbo 350, 2800 stall, and 3:73 gears
Old 07-11-2006, 09:34 AM
300hp to 325hp
go to http://www.ryanscarpage.50megs.com/combos1.html. And then go to combo 72 and 82, which are most like your engine.
The 882 heads and soft ramp cam is holding your engine back.
Old 07-11-2006, 10:30 AM
RHamm1320's Avatar
Last wiki edit: Computer dyno simulation and engine building softw... Last photo:
Wiki Edits: 3
A dual plane intake would really help alot. Your intake is wanting upper rpm horsepower and fighting the rest of your engine that wants to make torque.
http://www.nastyz28.com/sbchevy/sbccams.html
http://www.virtualengine2000.com
Old 07-11-2006, 10:38 AM
firestone's Avatar
http://teamrfc.gospelcom.net
I agree with the 300-325 estimate.
Adam
Old 07-11-2006, 12:36 PM
rac43's Avatar
Thanks for the replies so far and I really would appreciate your advice on how to get this 350 up to about 370-400HP. Can I do it by changing my intake and if so, please advise a good dual plane to use for min $. Do you think I get it up another 50-70HP this way or would I have to change cam? This cam is the same one used in the 69-70 350/350HP LT46 vett. Any advice would be appreciated.
Old 07-11-2006, 01:43 PM
firestone's Avatar
Pretty much the only way to make it have 370-400 hp and keep it streetable is to get a new set of heads. A new cam will help, but will not add that much. The dual plane intake will probably not add to the max power, but will creat more power on the low end. I think you are closer to ~300 right now. an XE274H (230 236 @.050 .490 lift) cam would probably take you to around 330. As far as which intake to switch to, I would recommend the performer RPM for $132 from Jegs.
Intake manifold: $132
http://www.jegs.com/webapp/wcs/store...tegoryId=11937
Cam: $175 (with lifters)
http://www.jegs.com/webapp/wcs/store...chItemId=29331
Adam
Old 07-11-2006, 01:51 PM
There's more power to be made with a well designed exhaust system than with a manifold change. I see you haven't described yours.
Old 07-11-2006, 01:52 PM
I would go with the Edelbrock Performer head (1000.00) and Edelbrock Performer RPM intake (180.00).
You have enough gear and stall to run a pretty big cam.
With the Edelbrock RPM heads and a modern cam grind with around 230 degrees of duration at 0.050" will get you past 400hp mark fairly easily.
Old 07-11-2006, 02:05 PM
Go to
http://chevyhiperformance.com/tech/e...est/index.html
They dyno'd 8 cylinder heads that cost under 1000.00 with a 383 and a XE274H compcam. Go down to the bottom of the page and check out page 3. The Edelbrock RPM heads made the most average power a had a peak output of 452hp and 491 ftlbs of torque. Of course, a 355 will make about 8% less in torque and hp as compared to a 383. So a similar built 350 would make around, 415 hp and 450 ftlbs of torque.
Old 07-11-2006, 04:42 PM
rac43's Avatar
I have custom made headers leading to a 3 1/2 inch collector dumping out of the sides. NO mufflers! Could not be more free flowing!
Old 07-12-2006, 09:48 AM
rac43's Avatar
Lots of great info above and my thanks. I am getting a Edelbrock RPM later this week to start with and will start looking for heads and a cam. Cam advise would be appreciated. I want to stay streetable and keep my compression to under 10-1 for street gas. From what I read above, a lot of you think my 882 heads are not up to getting up over 350HP, even with 2.02 intakes and 1.625 exhaust. Right???
Old 07-12-2006, 11:42 AM
65 Imp SS's Avatar
rac43 go to this web:
http://www.chevyhiperformance.com/techarticles/41598/
Then scan down to the sidebar articles and go to category 1 small block your head flow rating is there. Also there is a number of other flow ratings for s.b and b.b. chevy heads.
Old 07-12-2006, 01:47 PM
One of the largest errors street enthusiasts make is in running too large of a primary pipe, and too large of a collector. For example, NHRA and IHRA Stock teams using Burns' headers in H/SA in traditional small-block powered musclecars are running 1.5-inch diameter primary pipes- much smaller than many street machines are trying to use.
http://www.popularhotrodding.com/tech/0310phr_burns/
There's a difference between 'free-flowing' and 'properly designed'. If free flowing was the solution, you'd see everyone just blowing the exhaust out of the head. For a 350" motor, something in the 1.5" x 40" primary range and a 2-1/2" collector would work well. A 3-1/2" collector is way too large to do any serious scavenging at your operating rpm's.
Old 07-12-2006, 03:31 PM
rac43's Avatar
Here is a photo of my T-Bucket with the 350. It now does 0-60 in 4 secs flat so I think the 3 1/2" collecter is working perfectly, don't you! Thanks for the advise on the exaust!
Name:	Aa 5-24-6.JPG
Old 07-12-2006, 06:35 PM
No, I don't think they're working perfectly. They look pretty good, but the design is from the sixties. My 3450# daily driver Nova ran 0-60 in about 3.2 seconds with 1-5/8" headers, 2-1/2" collectors and full mufflers. I'll bet you could easily knock 1/2 a second off your 0-60 time with a properly scavenging merge collector.
Increasing HP on my Blown SBC with Cylinder Head Replacement 1950bulletnose Engine 5 03-04-2004 11:00 AM
68 Camaro engine advice Valkadesh Engine 2 01-11-2004 09:12 AM
what was the strongest year 350 stock from gm??? joe28boxer Engine 24 12-17-2003 11:21 PM
hp, torque, tranny, gear setup for '32 'glass roadster McDeuce Engine 0 10-08-2003 09:39 PM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 07:54 PM
