Better to ask and prevent problems
![]() I have broken in many engines on plain old normal 10w30 over the years and haven't had any problems, but I do agree that the diesel oil is logically better. I might suggest running the diesel oil anyway... even if its run at the factory. To hook up the tranny, you need a set of flexplate bolts (if its not already installed). I like to use red loctite on the threads. Then you need six 3/8" grade 5 or 8 bolts for to mount the tranny itself to the engine (or reuse your old ones), and you'll need some torque converter bolts (again I like to use red loctite) All of those are available at the parts store or from Summit racing. Make sure you get the TC seated all the way in the tranny. When you install the TC should be about 1/4-1/2" away from the flexplate. If they're touching or if it prevents the tranny from mating up the engine, its not right. |
Thanks.
I had read about a pilot shaft bushing for a manual trans, and thought there may be something else I over looked. I basically took a running motor with a T350 and bolted it in my GMC. So I didn't know if any thing else was needed. I have some experience with installing an engine, but not a new one. I also noticed two dipstick openings on the block. Could I tap one and put in a threaded plug or would a press in plug suffice? Or have his and her dipsticks. |
If it has a flat tappet cam in it then definately use Shell Rotella oil on the break in. If it has a Roller set up then its not really neccessary....but it still would not hurt anything.
This is a basic GM GoodWrench engine. The 290 horse model. I guess I should read up on what cam I have. I bought just a basic smallblock so I can build on it over time, like I would if I bought the truck new. Does the oil weight matter on the diesel oil? How hard is it to make an oil pump primer from an old distributor? Sorry for the hit and miss questions I keep thinking of new wrinkles in my plans.
You can tap the hole for a threaded plug, but I prefer little freeze plugs. That way you can use it as either side later if you choose by just removing the plug and you don't have to worry about metal shavings in a fresh assembly.
I think the plug is what I'm going to do. I dont want leaks. The last motor leaked like a screen door in a submarine. I hope to get the engine bay and underside of the truck scrubbed clean this weekend, I also have to reroute all the wiring for my airbag setup and figure out why the compressor keeps blowing fuses. Next weekend the motor and trans go in. I'm getting all of my info and pieces together so I can put this together as smoothly as possible.
Do as you wish, but I have more luck with freeze plug sealing than I do with pipe plugs. Think about the 15 psi the block sees in the coolant jacket and you never see a coolant leak from properly installed freeze plugs. They're also used at the front of the oil gallery where they see as much as 70 psi and you don't see them leaking.
The dipstick hole is 12" above the oil level, isn't pressurized, and never sees oil. Do as you wish, but I wouldn't risk metal shavings in the pan, nor would I permanently ruin that hole as a disptick position. |
Add a can of GM Engine Oil Supplement (EOS) to the break-in oil, and to the first oil change. Get it at the local Chevy dealer.
You camshaft is the old 3896962 hydraulic cam, used in 350hp 350 Corvettes (L-46 engines) in '69 & '70, and in mid-'70s Z-28's (L-82 engine). The part number may have been superceded, but it's the same piece. Duration at .050" is 224*, intake lift is .450", exhaust lift is .460", and lobe separation is 114". It's probably a little too much cam for the 8.5:1 compression ratio, but it'll run OK. I have the home-made version, a '72 L-48 350 with that cam installed. Won't ping on regular unless I forcibly lug it, but it's not what I'd call real strong down low. |
I have the 290 HP crate engine in my pickup, and the strong part of the torque curve doesn't seem to kick in until you get above about 3000 rpm. For use in a (heavy) pickup, I probably should have stayed with the basic 240 HP Goodwrench engine, which has a less aggressive cam.
I'm running an Edelbrock intake and carb, but didn't switch from stock exhaust manifolds to headers yet. A switch to the right headers might help the low end torque a little. Bruce |
Thanks for the info. I was going to have the truck running this weekend, but I have been sick since Friday night. I havent looked in the direction of my shop. It is a nice 55 degrees and sunny and I dont want to do anything but sleep, I even didnt even go to work today. Hopefully next weekend I will have everthing ready and get the truck running.
| 69' Camaro - Need Wiper Motor Replacement Advice | PrimaDude | Engine | 2 | 10-29-2005 06:08 AM |
| Price for an chevy blown crate motor? | Etiene Coetzee | Engine | 3 | 07-30-2004 06:45 AM |
| Price for an blower crate motor? | Etiene Coetzee | Hotrodders' Lounge | 1 | 07-30-2004 06:30 AM |
| "problems with a crate motor 350/330hp??" | ontokid | Engine | 5 | 09-19-2003 04:51 AM |
| 350 sbc crate motor questions | bentwings | Engine | 7 | 10-29-2002 08:03 PM |
