Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need advice on lift purchase
Old 11-17-2008, 08:36 PM
burnt olds burnt olds is offline
Originally Posted by model a guy
I have a two post lift. But I would not get another one. It takes too much time getting it set to lift a car. A four post is much better for the addverage guy I think. All you have to do is drive on it and lift. The short fall is if you are doing brakes. Then you have to let down on a support to lift the car off the rail you drive on. But think about it. I paid 900.00 for the one I have and I would give 1500. for a drive on any day. Thats how much trouble it is. Good luck
four post drive on , brakes , all you need is the jack sliding tray or a tall jack stand with added bottle jack .
them landings make great places for your brakes to be laid out and tools are in handy reach .
place for a drop light to lay .
them two post are not good for motor pulls , if you pull motor out , Topsy turby , out of balance .
plus you can't do any serious yanking and prying .
you can get a a movable type and store cars under and over .
no anchor bolts pulling out , cracking that most likely what 4 inch thick concrete .
