Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need advice on my Singer 111w155
Old 03-20-2013, 05:10 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
The bobbin tension is adjusted by loosening or tightening the screw on the left. (There is no screw in the hole on the left in this picture.) The rear screw just helps hold the bobbin case tension spring on the bobbin case.
The Following User Says Thank You to DanTwoLakes For This Useful Post:
61unibody (03-23-2016)
