Need advice from a structural engineer: makeshift garage - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-24-2006, 06:49 AM
matt_ramsey's Avatar
Your Basic Moron
here was my idea, first pic is the "garage" i threw up to keep the rain off my car whilst i primered & puttied it. the second is the same garage, after a few rainstorms. luckily, the car was painted by then. did i say "luckily"? I meant, "as planned". yeah.
that's how you'd do it out in the country anyways.
[IMG]gar1.JPG[/IMG]
[IMG]gar2.JPG[/IMG]
ID:	11132   Click image for larger version
  #32 (permalink)
Old 04-08-2006, 10:04 PM
Makeshift garage
From the look and sound of things it's time to call in some markers. Look toward some friends who have a garage or better suited shed/barn to work in. Check to see if there is a high school or technical school in your area that may do the work you need. Bottom line DO NOT put yourself in danger trying to use something that is not safe. You may find the cost of trying to make this shed into something to you can put your car in is more than you would pay someone to fix your car. Good luck whatever you do.
  #33 (permalink)
Old 04-09-2006, 03:14 PM
garage
how about have somebody else do it for you and convert all that building time and money into making money the best way you know how ..food for thought..........jb
  #34 (permalink)
Old 05-10-2006, 02:10 AM
makeshift garage
Hi, i just saw this thread, so i guess it's all over now, but the one thing i didn't see was to rent a storage for a month or so. if you are near a town with a mini storage, you could rent a 10x20, put your car in it, pull the engine, lock the car in it. return when the engine is ready to put in and put it together. if you also need room to build the motor, rent a 20x20.
storage units have varying rules, but i have been in several where they didn't mind you working on something in your unit. the only bad thing is there is usually only 1 light and/or outlet. it's cheaper than a funeral.
also i have used both kerosene and propane space heaters. i like propane better, as the fumes are not as bad. if you are painting, the kerosene fumes can make fisheyes in your paint job. after all it is oil. Doug
  #35 (permalink)
Old 05-10-2006, 02:58 PM
Zimmo's Avatar
Yeah, that's what I did...rented a 10 x 20 storage unit. No lights or outlets though. For the lights, I ended up getting an LED dive light that has a 40 hour run time on 1 set of batteries. Working only on my days off, it took roughly 2 months.
The biggest issue was the lack of heat. It was like working in a freezer. In the end, it turned out ok. I installed one of those used Japanese motors from this place http://www.import-engine-trans.com/
The total price was $ 825 with shipping & no core requirement. The engine was complete and it looked like it was only 1-2 years old with around 30k miles on it. Most of the sensors were compatible, except for the O2 sensor & distributor. The intake on the new motor was a lot bigger, and it had bigger fuel injectors. Same displacement as the original, but much improved on over the last 10 years in Japan.
My wife is pretty happy with it too. It has more power than the original motor ever did, at least 20% more. I did have to replace the radiator too because of the increase in horsepower.
Anyway, I gotta recommend this to any of you thinking about rebuilding a Japanese motor. I have an extra a/c compressor, power steering pump, & a brand new mini alternator that might work nice on my big block Olds project
Thanks again for all the advice
  #36 (permalink)
Old 05-10-2006, 03:12 PM
Zimmo's Avatar
Here's a pic...The new motor is in front. See the difference in the intake
BTW - the 10 x 20 storage unit rental was actually a little too narrow
  #37 (permalink)
Old 06-19-2006, 03:04 PM
Last journal entry: My Car
For your wife's sake , make sure you have good life insurance when you drive your car into your shed ,
Maybe its cheaper to have somone else do the work on your car , think about what your life is worth , maybe you can build one in the future , but for now build a good friendship with the local garage
Nova Kevin
  #38 (permalink)
Old 07-28-2006, 12:59 PM
Reconsider!
Zimmo
I grew up in a family of carpenters, and spent five years in the military as a construction engineer. I'm not a professional builder, but I was trained to do basic design and estimation in the military, which included estimated the weight a structure can handle. I don't have stress charts any more, but I've a godd idea how much a 6x6 can handle.
That said - please reconsider using that shed. All that weight is being transferred to the four posts, including the weight of the shed, anything else in the shed, and you. The odds are very good it will give way, possibly with you in it, and that's a hefty drop, especially with a car landing on you.
Is the possibility of you being crippled or dead worth the few bucks you'll save?
  #39 (permalink)
Old 07-28-2006, 02:37 PM
Zimmo's Avatar
Thanks for the advise guys
I ended up renting a shed a few months ago & replaced the engine there.
I'm in the process of designing my new custom garage to replace that shed. Hopefully fall of '07 I'll be posting pics of it.
  #40 (permalink)
Old 07-28-2006, 04:07 PM
conestogaman's Avatar
Mr. Excessive
And I was lookin' forward to the video...
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Some Garage advice Dreadlord Garage - Tools 18 05-15-2006 07:27 AM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
Look What's Coming On Monster Garage!!!!!!!!!!!!!!! willys36@aol.com Hotrodders' Lounge 10 01-20-2004 09:17 AM
