Need advice on universal rear frame kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2003, 12:39 PM
Hey guys I need advice on what i need to do to my Plymouth. My father pretty much gave me his 68 Road runner . When I started to remove the rear end i found out that one of the frame rails was bad. So i started looking into replacing the rear frame with either a universal four link or ladder bar setup in the Summit Racing catalog. This car is going to see a lot of street use so i wanted a functional setup. I plan on running a 17 or 18x11 wheel with the fattest tire avail so i dont mind tubbing it. Does anyone know if a setup like this would work for my application? I also plan on instaaling the kit myself and wanted to know how difficult it actually is to install one of these kits into a car like or similar to mine. PLEASE HELP
Old 08-29-2003, 02:23 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
For an 11" wide rim/tire, you wouldn't need to do a whole tub job, a mini tub would work, along with probably some shock and spring relocators. How bad is the frame currently, and is it fixable?
Old 08-29-2003, 09:55 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
A new frame section is a big undertaking. Very Big! I would suggest trying to fix or replace with an original and do some mini tubs unless this is a race car.
Chris
Old 08-30-2003, 07:42 AM
adtkart@aol.com
Like Chris said, unless you have some knowledgeable help available "on-site", that is a big undertaking. Not really something you want to try by yourself.
Any chance you could post some photos of your problem? I am sure someone could give you some suggestions that may be easier/better for your situation. There is alot of experience on this board, and most are more than happy to help to make it a fun and exciting experience for you.
Keep in mind that many street rod projects are scrapped because people undertake a very complicated project that they are really not ready for, both financially and experience wise.
Not to sound grimm, but most times the chances of a project being completed, are directly related to the amount of time and money it takes to get it back on the road.
Old 08-31-2003, 12:55 PM
Thanks for the responses. With the car I plan on racing it , but for now I want a serious cruiser. I really just wanted to have a trick suspension setup, and liked the idea of installing either a four link or a ladder bar setup. The rear frame rails aren't that bad. I dont have a camera so I cant post pics. As far as installing the kit I'm not going to do this by my self.
