Need advise. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2008, 06:18 PM
GMCTRUCKS's Avatar
Need advise.
My brother is thinking of buying a Mig or Tig welder he's just going to do light work around his house what would you guys buy and why? Thanks!
Old 04-18-2008, 06:33 PM
poncho62's Avatar
Wiki Edits: 5
moving this to the Garage-Tools forum....you will get a better answer there..
Old 04-18-2008, 07:21 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
For general use, I would by a MIG....they are easier to weld with and cheaper to buy also.
Old 04-18-2008, 08:53 PM
awert's Avatar
58/58
Need advise
TIG is pretty expensive,and more difficult to learn, mig is a good all around choice, ez to learn, also consider you should really have argon, and 220 volt if you want a nice looking weld, and you plain on welding more than tin cans together..... Lincoln's 130 is said to be a real nice little MIGer....
Old 05-15-2008, 06:47 PM
hotrod66_57's Avatar
Last journal entry: dolly
Yeah, MIG for sure. Much less steep learning curve than TIG. With TIG unless you've done extensive Oxy welding before I found it pretty hard to pick up, way more going on with the non consumable electrode, foot pedal, and welding rod and what not.
Need some advise on ABS plastic repairs USAF Chief Body - Exterior 1 11-01-2006 07:56 PM
Advise for a 454 first time builder My-first-rat Introduce Yourself 2 08-03-2006 05:07 AM
Need advise. 01 Saturn SC1 tranny 383MontecarloSS Transmission - Rearend 5 01-10-2006 05:01 PM
Advise need on building SBC Pittbull Engine 6 11-28-2004 08:00 AM
advise needed on rear end selection? tonylsg Transmission - Rearend 1 02-12-2003 03:39 PM
