Need advise on how much - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2007, 10:16 AM
stoney 81ta's Avatar
Have a chance of getting a 327sbc 325hp-300ftlbs large journal 68-69 crank zz4 cam all gm built roller for 1200cdn.Engine has about 20k on it since built in 1994,need valve seals,motor is complete minus dizzy.What do u guys think?Thanks all.It will be going in a 81 TA.
Old 03-02-2007, 09:22 AM
does anyone have any thoughts on the 327 in the above post.Is this worth buying.Also if i do decide to get it any ideas on how to get maybe 50 mo hp if possible.Thanks all
Old 03-02-2007, 09:40 AM
Animal's Avatar
Dominators Hot Rod Club
Last journal entry: On the run
You should be able to get a decent LS1 for a little more than that. Just a thougt
Old 03-02-2007, 12:05 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
1 hp per ci is not too shabby.
Getting 50 more would probably require new heads, cam, and induction.
You could probably find a low mileage donor 5.7 roller vortec for less money and add good cam and induction and reach 400 easily.
Old 03-02-2007, 11:11 PM
thanks all for your replies
Old 03-03-2007, 09:03 AM
What heads are on the motor now?-this could make a big difference in value.
Old 03-03-2007, 09:19 AM
What heads are on the motor now?-this could make a big difference in value. Ithink they are chevy bowties heads with angle plugs waiting to get the casting numbers.
Old 03-06-2007, 10:42 AM
Update on some of the specs of the motor-Block 92 gmc roller cam block bored .030 no block numbers yet. crank-68-69 327 large journal.Rods 327 rods.Pistons .030-9:1 compression.Cam zz4 .470 intake lift/.510 exhaust not sure of the duration.Heads are iron chevy bowties #1401134.What i like to know is this setup would give me good up and go power in the idle-5500 rpm range as im using a stock 350thm tranny 2.56 rear end gears.Thanks all.
Old 03-10-2007, 05:08 PM
81BlackTA's Avatar
I've got a similar setup in my 81TA. Except its a 350. If my crank wasn't so good, it would be a stroked 383. I would guess that engine was previously blown up, maybe the reason for the shorter stroke crank?? It should work reasonably well, but if I were you and had an extra $1000 to play with, I'd get a stroker kit . Hold on then.
The 2:56 gears will never really give you a good launch althgough you should be able to go 140 mph if the car is up to it. Mine came with 3:08's and that was ok...but not as much fun as the 3:42's in it now. If you are going to plan on changing the gears, be careful. You might have to change the carrier as well. There are apparently 2 different carriers for the GM 10 bolt that is in your car now. You might want to research that a bit.
That block should also be a 1 piece real main seal block. I would inquire about that. The 327 crank is for a 2 piece rear seal. Why is he selling it?. It sounds kinda cheap. I paid a grand Can$ for an 89 zzz 350 short block that was still really fresh and that I thought was a smokin deal. No cam or heads. How do you know it needs valve seals? Buddy said so? Good chance it might need guides as well. The more I think about it, the less I like the sound of it. Just my opinion. I'm not a pro, but have been around.
Old 03-10-2007, 05:12 PM
81BlackTA's Avatar
One more thing stoney...if you car is a t-top and you replace the stock 305 lump that it came with, I strongly recommend a set of subframe connectors.
When we repainted my car last year, I had a small crack issue at the quarter panel to roof seam area. And that was with the stock soggy 305.
Need some advise on ABS plastic repairs USAF Chief Body - Exterior 1 11-01-2006 08:56 PM
Need advise. 01 Saturn SC1 tranny 383MontecarloSS Transmission - Rearend 5 01-10-2006 06:01 PM
Advise need on building SBC Pittbull Engine 6 11-28-2004 09:00 AM
advise needed on rear end selection? tonylsg Transmission - Rearend 1 02-12-2003 04:39 PM
need advise from the experts warlock Engine 4 02-09-2003 05:52 PM
