Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need advise on testing msd btm with pump
Old 12-05-2012, 04:00 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Vacuum is the oposite of boost pressure. The pump needs to create pressure.
If it cannot be reconfigured to be a +pressure pump, it will not work for you.
@ just 5 psi boost you should not need much retard. (assuming good fuel)
