Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need advise on testing msd btm with pump
Old 12-06-2012, 09:59 PM
menoaz's Avatar
menoaz menoaz is offline
Tested the btm today with the air compressor set atat 5psi. Moved the btm knob from 0 to 3 and watched with the timing light the timing go down just like its simulating boost. So from what iv read in threads im going to set btm to start taking out timing at 1-2 lbs of boost and going to take out 2 degrees of timing per lb of boost. car ran 12.1 with no 8-71 so im hoping for a low 11 to high 10's with 5lbs of boost. Going to make some passes at 5000rpm shifts and make sure everthing is staying together
