Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need advise on testing msd btm with pump
Old 12-13-2012, 11:24 PM
menoaz's Avatar
menoaz menoaz is offline
Ran the car at the track and and video taped the boost and tach. Didn't get 5lbs of boost until around 6000rpms. Then ran into more problems with rams raising way to quick and not going down when I shift. If my converter is flashing to high would it still let the tires come off the ground. So I'm going to change my gears from 4.88 to 4.10s see if that helps before I spend a bunch on a Hughes converter.
