need advise on testing msd btm with pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2012, 02:52 AM
menoaz's Avatar
Im going to the track this weekend for the first time and running only 5# of boost on the 427bbc with 8-71. Here at home i cant get enough boost into the btm to show me that it works like it should when i got #5 pounds at wot. I can only get #2 of boost on the gauge. @4000. I have the knob all the way to 3 degrees removed and starting at 0 pounds of boost. I have my timing at 38. I see no retard when i rev it up past 3500 with the timing light.. so im planning on buying a handheld vacuum pump from autozone and testing the btm. So any advise on using the pump? Rpms? how much vacuum on pump equals 5# of boost.
Old 12-05-2012, 05:35 AM
menoaz's Avatar
Okay thxz, so it has to say pressure pump. Do you agree that timng should not be coming out until 2# of boost starts? Im planning on mixing 50/50 91 octane and 110 race.
Old 12-06-2012, 09:59 PM
menoaz's Avatar
Tested the btm today with the air compressor set atat 5psi. Moved the btm knob from 0 to 3 and watched with the timing light the timing go down just like its simulating boost. So from what iv read in threads im going to set btm to start taking out timing at 1-2 lbs of boost and going to take out 2 degrees of timing per lb of boost. car ran 12.1 with no 8-71 so im hoping for a low 11 to high 10's with 5lbs of boost. Going to make some passes at 5000rpm shifts and make sure everthing is staying together
Old 12-14-2012, 12:24 AM
menoaz's Avatar
Ran the car at the track and and video taped the boost and tach. Didn't get 5lbs of boost until around 6000rpms. Then ran into more problems with rams raising way to quick and not going down when I shift. If my converter is flashing to high would it still let the tires come off the ground. So I'm going to change my gears from 4.88 to 4.10s see if that helps before I spend a bunch on a Hughes converter.
8-71, blower, boost, btm, msd
need advise on testing msd btm with pump menoaz General Rodding Tech 0 12-04-2012 08:59 PM
MSD 6-BTM Ignition Box Not Working Aaronk227 Electrical 0 11-24-2012 09:11 AM
testing msd 6al with hei mainejohn Engine 1 03-06-2011 04:18 PM
MSD and Electric fuel pump Curtis Thornton Electrical 1 10-18-2010 08:12 PM
MSD coil testing joe350s10 Electrical 14 02-16-2006 11:35 AM
