Need air hose help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2013, 04:34 PM
1955 Victoria
Need air hose help
Ok so I have the compressor on the way but am a bit confused about air ine sizes. The outlet is 1/2" so not sure if I need to run all 1/2" hose or should I drop down to a 3/8". Also, is it normal for the 3/8" to have 1/4" NPT fittings?
Sorry for the questions but this is not something I am familiar with.
Old 09-24-2013, 05:41 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
Air Piping Layout
The Science Behind Piping Your Air Compressor
What Pipe to Use for Your Shop's Compressed Air?
The Following User Says Thank You to hduff For This Useful Post:
AP_photo (09-25-2013)
Old 09-24-2013, 06:04 PM
1955 Victoria
Thanks for the links. Right now I am just trying to get a regulator/filter and an air hose. Not wanting to pipe air in the garage
Old 09-24-2013, 06:27 PM
hduff's Avatar
Then get the larger diameter hose, but expect some water to make it through the tool you are using no matter what you do.
Old 09-25-2013, 05:58 AM
1955 Victoria
Thanks. Right now my budget has been exceeded so just need to get it running right now.
Air hose repair fatrat Garage - Tools 3 10-10-2009 10:49 PM
Does air hose I.D matter? acquadigio79 Body - Exterior 18 08-05-2009 01:03 PM
air hose mitmaks Garage - Tools 6 10-24-2007 08:31 PM
What size air hose should I use? FrankR Garage - Tools 1 04-11-2005 03:09 PM
Air hose length orb Body - Exterior 12 02-04-2005 07:50 AM
