need answer about motor mounts fast!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2007, 11:12 AM
does anybody know if the the chevy v6 and buick v6 use the same motor mounts? I have a 81 malibu with a chevy v6 and will be putting in a grand national buick 3.8 v6 and need to know if the mounts will work. thanks..
Old 02-02-2007, 12:00 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
call the local parts store
Old 02-03-2007, 08:02 PM
The mounts are different. In fact, both the rubber mounts and the metal brackets are different between the two motors. You'll need the correct Buick mounts.
Old 02-03-2007, 08:55 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
As Joe said, the Chevy 229 uses different mounts than the Buick 231, but 81 Malibu's came with both the 229 and 231 engines ... so are you sure the frame mounts are different too, Joe?
NAPA Online
229 Chevy
NAPA BKP 602-1379 LH
231 Buick engine
NAPA BKP 602-1390 LH
82 Regal (Grand National) as well as 84-87 (There was no GN in 83 according to Wikipedia ) all seem to use the same mount as the Malibu 231.
Old 02-03-2007, 11:15 PM
thanks for the help, they are indeed different, picked up the motor mounts but need the frame mounts, napa don't sell them. any idea's where to buy them?
Old 02-04-2007, 09:14 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Are you sure that the frame mount is different?
I had an 80 Monte that came with a turbo 3.8 Buick, I later changed it for a SBC, I had to move the frame mounts to make it work with the Chevy but they were still the same mount. (holes were already in the cross member, nuts on the back side were a pita to get to)
Old 02-04-2007, 10:18 AM
At some point in the 1980s, Chevy went to motor mounts with the rubber on the frame side and simple metal brackets bolted to the block. Buicks are the other way around (rubber on the mount that bolts to the block, metal bracket on the frame). That's what I think is shown in the pictures in a previous post in this thread. Whichever side is which, you'll need the matched set. The metal brackets are non-wear items and are not stocked at parts stores. You'll need to make a wrecking yard run to get them.
Old 02-04-2007, 04:22 PM
xntrik's Avatar
according to Wikipedia ) .
There are numerous errors in wikipedia on many subjects. I'd find more info.
Old 02-05-2007, 09:26 AM
You mean not everything posted on the internet is 100% true? I'm SOOOOO disillusioned...
Old 02-05-2007, 11:54 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
If you are POSITIVE there is an error in Wikipedia, CHANGE IT!! That's what the "edit" tab is for. you don't have to register to make changes, but if you're going to watch a topic (or several) and make frequent changes you should. Just MAKE SURE you're changing bad info to good -- make SURE you have a reliable source or you have actual hands on experience. Not doing much good to edit heresay with more heresay. And don't trust your memory!
Being an AMC guy I ALWAYS get people telling me wierd things they remember about the AMX/Javelin/Rambler they had years ago, and will swear it's gospel truth even when I have a factory serivce manual in hand and can show them different -- "must be a typo"... though a few will fess up that "it was a long time ago". I generally don't argue with anyone who tries to remember way back though, not unless they're telling some newb who really needs to know the info.
Oh yeah, I'm wrong on occasion too when going from memory!
Old 02-05-2007, 06:05 PM
66GMC's Avatar
As the old cliche goes..
"Yeah, I thought I was wrong once, too ... but I was mistaken."
That's good info on the Wiki thing, and a valid point that you should check alternate sources to confirm IMPORTANT facts. (Whether or not they made Buick Regal Grand Nationals in 1983 or not is non life-threatening information, in my opinion. )
I also agree that people should qualify their "I know for a fact" statements with first-hand experience or at least include an "according to:" if they're not 100% sure.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
GM Fast Burn Heads bigjoedo Engine 4 01-02-2007 10:46 AM
QJet -- What Controls Position of Fast Idle Cam? JohnTN Engine 8 09-17-2005 08:17 PM
fast idle frydz1985 Engine 1 10-19-2004 11:12 AM
a fast formula HELP! chris oswalt Engine 2 09-17-2004 11:22 AM
