need answer for Desktop dyno 2003 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2009, 04:20 PM
pena0724's Avatar
i am running a desktop dyon and it is asking me if my heads are low preforamce stock ports valves or wedge pocket porting stock valve
what i have is a sbc 350 with dart pro one heads 180 runners 64cc 2.02/1.60
Old 08-05-2009, 06:47 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
That is one of the problems with getting numbers anywhere close to accurate from Desktop Dyno. That version should have an option to input port flow numbers at various valve lifts. There are probably flowbench test results posted on the internet. Try Googling it and see what you come up with. Remember though, even with flow numbers you need to take Desktop Dyno results with a grain of salt. But.....it's better than a kick in the pants I suppose.
Old 08-05-2009, 09:15 PM
Wiki Edits: 31
you need to go to custom on the drag drop down list and input the flow chart that the cyl head manufacture provides
Dyno tuning Process HELP! Ratchet Engine 15 02-25-2008 10:57 AM
dyno - never again goldbird Engine 17 08-24-2006 07:05 AM
7 clylinder dyno juiced66malibu General Rodding Tech 1 07-31-2006 12:42 PM
desktop dyno 2000 = are they truthful 406 ss monte Engine 24 07-25-2005 06:57 AM
Anyone with a desktop dyno? abe Engine 7 02-08-2003 03:15 PM
