-   -   need an answer fast--don't want to go to parts store (http://www.hotrodders.com/forum/need-answer-fast-dont-want-go-parts-store-202036.html)
yragat 07-15-2011 09:48 AM
I'm in the process of splitting the wire from coil to ignition and putting in a hidden toggle switch. The wire I'm splitting is 14 ga---all I have is 16 and 12 ga----can I use the 12?
cobalt327 07-15-2011 09:52 AM
Yes you can use the heavier 12G wire.
david-b 07-15-2011 09:52 AM
Should have no problems with the 12. Not a huge difference between 12 and 14
yragat 07-15-2011 09:53 AM
Thank you :D
joe_padavano 07-15-2011 01:18 PM
You can always use a heavier wire. Just don't use a thinner one.
yragat 07-15-2011 01:27 PM
Thanks,guys----got it! :D
T-bucket23 07-15-2011 02:41 PM
If you are installing a kill switch that is not the best way to do it
yragat 07-15-2011 02:44 PM
I'm just doing it so if I leave the key in the car,with that switch off it won't start
Any suggestions are always welcome---what do you suggest :confused: ?
