Need Answer Fast - SBC LT1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2008, 08:51 PM
S10 Racer's Avatar
http://www.warsprints.com
What is the difference between the early model SBC motors and an LT1 motor out of a 1996 Z28? Will the heads off of the LT1 fit a 70's 350 or 400 SBC?
Thanks
Old 01-07-2008, 09:22 PM
Siggy_Freud's Avatar
Quick answer, no. LT1 heads will not fit an early sbc. The LT1 is a reverse flow engine in that coolant flows in the reverse direction. The coolant ports (as well as others I believe) do not match up.
Bringing history and technology together.
Old 01-07-2008, 09:52 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Do a search, tons of info recently here.
There are similar in some aspects; crankshafts, pistons, rods, valvetrain, and a couple other tihings interchange. Heads, water pump, intake, distributor, timing set are all different.
Old 01-07-2008, 10:08 PM
It has been done,but the coolant ports have to be welded up heads re surfaced new ports drilled,In the end its not really worth it,I had a website where they put LS series heads on a FORD but then my bookmarks went bye
bye .
Shane
Old 01-08-2008, 12:07 AM
As was mentioned, it could be done (but really what can't these days). But its not really a viable solution and will be more expensive than almost any other alternative.
LT1 rods from 94/96 caprice/ for 400 sbc el Engine 10 01-17-2008 05:23 AM
Vortec heads on LT1 the dan Engine 14 12-29-2007 04:24 PM
1-piece sbc flywheel vs LT1 flywheel curtis73 Engine 2 12-02-2007 05:02 PM
eaton m112 blower sbc manifold? oklowride Engine 3 12-25-2006 01:21 AM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
