Need axle reccomendation for A bone - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2012, 09:48 PM
Elevinpointsixtoone's Avatar
So those of you with slammed, channeled, fenderless model A's what rear axle is wide enough to clear the body? My math tells me with a shallow 3.5" backspace on the wheel I'll still need around a 66" wide axle (wheel pad to wheel pad on the drums)! There aint many of those out there.....
The body is 55" wide, add an inch on each side for tire to body clearance, add 7" for the back space and another 2" for tire hang over on the wheels and we're at 66". Not sure what to drag out of my local pick N pull. What are you guys running?
Old 01-25-2012, 10:22 AM
Come on now, I know you model A guys are out there....
Old 01-25-2012, 10:47 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would look at full size 1/2 ton ford pick up 8.8" or 9"
Old 01-25-2012, 07:08 PM
I'm hearing a 90-2005 Crown Vic 8.8" might do the trick...anyone know what these things measure out to?
stall speed reccomendation powerrodsmike Transmission - Rearend 6 07-21-2009 08:28 PM
Reccomendation between two cams. eric32 Engine 16 11-29-2008 09:47 AM
Carb Reccomendation Please 1985fiero Engine 4 09-29-2005 06:55 AM
Reccomendation for gauges? dinger Hotrodding Basics 10 04-24-2005 03:52 PM
web site reccomendation nzsimon Hotrodders' Lounge 0 10-02-2001 02:33 AM
