We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 07-02-2009, 07:17 PM
haulinass-10 haulinass-10 is offline
need boost
hey i have a 350 in my 87' s10 with a .502/.510 hyd. roller cam, and i just drove it around the shop yesterday and noticed the brakes didn't have much vacuum, could this be because of the cam? is there anythign i can do to get more vacuum?
Old 07-02-2009, 07:38 PM
jeff79's Avatar
jeff79 jeff79 is offline
Need more info
yes that is a healthy cam but what intake do you have and what heads with port sizes and such.... if you are running a single plane intake and healthy breathing heads then you may be suffering from low vacume and the brakes may be suffering from this..... I would first verify that you have no vacume leaks and that the booster is holding vacume..... If everything is good then you need to hook up a vacume gauge and find out how much vacume you are producing from the intake.... You may need to buy a vacume resivore to hold vacume...
Old 07-02-2009, 07:48 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
eloc431962's barnstar
Wiki editor
Last wiki edit: Hand cleaner
Wiki Edits: 17
Yes there are ways to get more vacum, but first you need to do what jeff said and check those things out first, check and see how much vacum you have now power brake booster needs 14-16 inches of vacum to run the power brakes properly or in most cases. Some people will disagree i am sure. JMO Cole
Old 07-02-2009, 07:53 PM
its a dual plane high rise edelbrock performer rpm and they are edelbrock aluminum performer rpm heads 2.02 1.60 and i think 64cc but i'm not positive about that. yah when i pull the vacum plug out it makes a pop so that shoudl mean that the booster works right? i switched from the single plane booster to the dual plane( thicker but less diameter) because it was too close to my valve covers. how do i check my vacuum pressure?
Old 07-02-2009, 08:51 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Threading tips
Wiki Edits: 210
In my experience, it takes 18" hg to operate 'em PROPERLY. You can stop the car with 14-16, but not as easily as you can with 18.
Use 14-16 degrees initial ignition timing at the crank and tailor your centrifugal advance in the distributor to limit total advance (initial + centrifugal) to 36 degrees or a little less.
Advance the camshaft 2-4 degrees.
There is vacuum and there is pressure. There is no vacuum pressure. Manifold vacuum is measured in inches of mercury (in. hg). On the front of the carb are two vacuum ports. The bottom one is manifold vacuum. Connect a rubber line to that port and the other end to a vacuum gauge. Read the gauge.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "need boost"
Cheap boost idea. What do you think? V8 Super Beetle Engine 45 05-07-2009 03:47 PM
Supercharger boost Question. rising68 Engine 2 12-31-2008 07:49 PM
when you boost an engine, does its VE go up ? lowROLLERchevy Engine 4 05-05-2005 07:45 AM
Turbo or Super? (Forced Induction Systems: Pro and Contra) Nightrider Hotrodding Basics 4 02-14-2005 10:50 AM
Boost 700R4 ChevyVan Transmission - Rearend 2 01-12-2004 02:51 PM
