Need to build a 351w - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2007, 08:11 PM
I have a 351 windsor H.O. out of an 84 bronco and was wondering what difrent about it other than it being a 4bbl and i was woundering what a good build for it for abound about $1-2 thousand would be for it thanks
Old 04-25-2007, 09:49 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
Unfortunately "HO" in the case of 351W's in Ford trucks and vans means nothing but a crossbreed Holley 4bbl carburetor and a cam designed to produce low to moderate RPM torque.
Just a generic 351W otherwise. With a moderate price rebuild and careful parts choosing/shopping you can look for 300 HP. 350HP maybe if you're good. This is assuming you are going to do as much of the needed work as possible yourself. Throw buckets of money at it and you can make lots more. If you pretty well have to pay for all the work done on the rebuild, just your most basic stock rebuild will pretty well blow your budget.
Hedman Hedder question 351W xntrik Engine 0 02-16-2007 09:07 PM
build a moter or buy a car first? Tryin2MakeIt Engine 19 12-13-2006 09:43 PM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 01:48 PM
351w main caps 1969NovaSS Engine 16 11-20-2005 04:20 PM
Building a 351W TonyMadrid Engine 5 04-18-2003 02:24 AM
