need to build up a strong 700r4 burnt up my last one - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2012, 09:05 PM
Project89's Avatar
i just burnt up the 700r4 in my twin turbo camaro, it was a decently built piece.
tci rebuild kit
mega boost valve
vette servo
beats sunshell
shift kit
any advice to build the next one even stronger
id also like no engine braking except in 1st gear if at all possible
Old 01-10-2012, 06:29 AM
Last journal entry: Still running strong
700r4 burnup
Sounds like you might have to much engine for a 700r4.Their only good for / up to 550 HP. 4l80,4l85,TH400 is what you need..
Old 01-10-2012, 07:47 AM
SSedan64's Avatar
X2^^ on the 80E/85E.
I'm sure that's producing lots of low end torque. Pressure rise probably isn't keeping up with engine's output. A Constant Pressure Valvebody would be an option but, as 'Dogwater' said, probably too much power for the 700R4.
Lonnie at Extreme Automatics has a better designed ValveBody for the 2004R than TCI's CP ValveBody, He may also make them for the 700R4. His supplies constant Max pressure in 1st, 2nd & 3rd gears but, allows TV cable controlled variable pressure in 4th gear. This takes the strain of the Pump when cruising in OD/4th to prevent premature wear.
Also has bolt on SFI 80E Bells for just about any Engine combo.
http://www.extremeautomatics.com/tra...ons/4l80e.html
Old 01-10-2012, 08:58 PM
Project89's Avatar
thats prolly how i broke it i still dont know what broke yet need to get it out of the car.
the other night i was rolling down the street in second gear and decided to test the antilag out. i had it set for 2500 rpms so i pushed the button put my foot to the floor and let the boost build and when i came off the button there was a loud pop the car jumped and then nothing motor just free reved and hit the limiter.only 1st gear works now and it has no engine braking
the guys over at probuilt said they can build me one to handle the power my car will make on high boost but i may just swap to a th400 or 4l80 with a full manual valve body so i dont have to worry about the ecm, since i want a transbrake for the car
700R4 lost 4th smells burnt Fergusonic Transmission - Rearend 2 05-30-2010 05:30 AM
help me build a strong high reving small block 400 mopar dman16 Engine 53 08-27-2009 11:06 PM
Is my stock 700r4 strong enough? pb9882 Transmission - Rearend 4 05-13-2005 10:37 AM
Rebuilt 700r4 Burnt in 10 miles subman17 Transmission - Rearend 9 02-15-2004 03:41 PM
700R4 strong enough??? catdad2u Transmission - Rearend 7 11-25-2002 08:15 PM
