Need to bury an electric wire - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-03-2011, 10:57 AM
Originally Posted by dinger
You're going to miss them night-crawlers when fishing season opens.
Considering how much power was leaking off into the ground they were some really expensive Night Crawlers!
  #17 (permalink)
Old 05-05-2011, 01:20 PM
The very first thing you should be doing about this is to call your Authority Having Jurisdiciton(AHJ) to discuss the issue. Depending on the point of delivery as determined by the AHJ, they may take care of the problem free of charge.
If you are going through with your own work, get a copy of your AHJ's service requirements to ensure you meet their standards with your work. It would be very frustrating for you to get all done only to find out your AHJ and/or state electrical inspector doesn't approve and you have to dig it all up again.
  #18 (permalink)
Old 05-05-2011, 06:15 PM
ogre's Avatar
the 'Duracell Project'
^^ ya right
my question is: why not bury a 100 amp service out there?
  #19 (permalink)
Old 05-05-2011, 06:39 PM
Originally Posted by ogre
^^ ya right
Well this is just a small side shop and will never need much more than a couple of light bulbs, a small bench grinder and a few hand tools. As far as inspection there is not much point in making it perfectly legal as long as it is safe because the whole thing is actually little more than just an extension cord from my main shop. This thing is located on a farm and the building it is going to would be considered an out building or shed even though it is insulated and has a concrete floor, it is mostly used to park tractors and such in. All I was trying to do was bury the wire out of harm's way and prevent power from leaking off into the ground.
  #20 (permalink)
Old 05-09-2011, 07:01 AM
Old Fool's Avatar
If I was going to dig a ditch to bury the cable, I would spend the few dollars extra and put in pvc conduit. next time it goes south, all you will have to do is pull a new conductor, not dig a new ditch.
  #21 (permalink)
Old 08-01-2011, 07:19 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I use UF cable underground splice kits from the local electrical supply house. The newest ones have a corrugated plastic sheath cinched on with zip ties that contains a clear, sticky goo. Not cheap, but never a problem with them.
  #22 (permalink)
Old 08-02-2011, 07:34 AM
cal1320's Avatar
The following is completely illegal and I don't recommend it. (but it will work)
Slide a 12'' piece of 1'' PVC over one side of the break. Wire nut conductors together and fill wirenuts with silicone. Slide PVC over splice and pump entire PVC sleeve full of silicone. Note location of splice for any future needs and bury.
  #23 (permalink)
Old 08-02-2011, 07:42 AM
The wire has long since been buried using these as per the suggestion from one of the members here,
http://www.elecdirect.com/catalog/53...Fctw5Qodhjtuow
  #24 (permalink)
Old 08-27-2011, 03:01 PM
bigtread's Avatar
Electrical work is not a hobby, hire an electrician
  #25 (permalink)
Old 08-27-2011, 04:46 PM
Powork's Avatar
used those splice kits for our continues duty fire pumps over the side of the boat @ about 10' below surface never had one fail, should work great for your app.
Question on wire size for Holley electric choke grobb284 Electrical 5 04-13-2009 02:42 PM
Help me wire my ELECTRIC FANS! DarknessSpawned Electrical 8 12-11-2008 09:43 AM
Fuel pump, electric choke and windsheild wipers on same wire sexypizzaman Engine 8 06-05-2008 07:23 PM
Electric Choke Wire GCD1962 Electrical 4 08-18-2007 08:25 PM
OEM electric fan wire colors sedan_dad Electrical 0 06-12-2002 02:26 AM
