Need to bury an electric wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 07:57 PM
I have buried many feet of electrical wiring over the years but as a rule I tried never to bury a splice because of the difficulty of keeping water out (and keeping the "juice" in!). I just discovered that I have been, for several years now, spending an unknown sum of money every month electrocuting Night Crawlers because my buried wire from my main shop to the small one had several connections that had just been taped before the wire was buried. I discovered this when the 50 AMP breaker started tripping when it rained recently but it obviously has been exposed for a long time.
Ok, I have two sections of new 10/2 weather proof (direct burial) wire that I need to splice in order to make the 75' I need and I don't want to have to buy new wire when I already have it just to avoid making a splice. Any suggestions on making a WATERPROOF and safe for damp ground splice in this wire?
BTW, the old wire was a lot heavier and the new set-up will only use a 30 AMP breaker.
Old 04-30-2011, 08:04 PM
pvc conduit and a waterproof junction box.
to do it by the book the junction box should be exposed at ground level.
to do it right you need 75ft of wire
Old 04-30-2011, 08:20 PM
That's the way I have always done it in the past but I thought maybe there is an acceptable way of waterproofing a splice on this thing. As long as it is safe I don't care if it is "by the book" or not because it is just going to a small shop to run lights and small hand tools, like I said as long as it is safe! I will not do anything if it might lead to someone being injured even if the danger would not occur for years.
Old 04-30-2011, 08:36 PM
Get some self fusing rubber/silicone tape and repair your splice then wrap over it with some plastic wrap and tape it up and you should be good to go for years to come.You can get the tape at electrical dealers or well pump suppliers or order it from McMaster Carr or Grainger.
Old 04-30-2011, 09:08 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Her are direct under ground splice kits, I think you'll like these.
Rich
http://www.elecdirect.com/catalog/53...Fctw5Qodhjtuow
Old 05-01-2011, 06:49 AM
Steel's Avatar
The Ultimate Lurker;)
The splice kits are the way to go. However, I generally only ever use the splice kits on larger multi-conductor cables. Usually on the smaller non signal carrying conductors I use a combination of Scotchkote(an electrical sealant), rubber tape, and black vinyl tape, with copper butt splices.
Use it in these steps:
1: Crimp on corresponding copper butt splice
2: Apply ScotchKote over entire splice area into 1 inch of insulation
3: After allowing the ScotchKote set up for a couple of minutes, apply a tight wrap of rubber tape covering entire splice surface
4: Repeat step 2
5: Now after allowing the ScotchKote to set up again, apply a tight wrap of vinyl tape
6: Repeat step 2 again
When you do this be sure you do one conductor at a time and stagger the splices. When you complete all your splices, tape all the splices up together and apply a final coat of ScotchKote and your done!! When done correctly these splices will out last all of us....
Old 05-01-2011, 07:50 AM
delawarebill's Avatar
bury'n a splice
for me, and thats me.. i don't like to splice and then bury it. wether its direct or in piping.. your going 30a and getting a full run one pc ain't a hole lot of bucks.. IF for some reason in the future u have ANOTHER problem u gotta dig it up so u better take a measurement and know where that splice is..
sorry but i'd be rethink'n this splice thing... but again thats me.
Old 05-01-2011, 07:57 AM
Wiki Edits: 27
submersible pump splice.
they make splice kits for submersible well pumps and they are rated to be in a WET enviroment. Check out a pump supplier- farm irrigation supplier. I have underground elect and water to my pasture for the horse water trough and ice melt heater I need to move one. I don't remember how much slack i left in the wires before I brought the wires into conduit and up to the post mounted box but will have the pieces on hand .
Old 05-01-2011, 08:03 AM
Yep, there are under ground splice kits as well as the well kits. Both are the same principle. Need the line marked well for future diggers safety. The best marking is on a drawing that can keep digging safe.
Trees
Old 05-01-2011, 08:11 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would use a shrink wrap or shrink wrap tube on it after you tape it up real good. JMO
Cole
Old 05-01-2011, 10:41 AM
Originally Posted by richard stewart 3rd
Hi
Rich
Yes that's what I need! I will get a couple of extra one's since I have run into this before and needed something like this.
I already posted this reply earlier this morning, don't know where the dickens it went?
Old 05-02-2011, 01:13 PM
Last journal entry: getting started
splice kit
I have used this a few times for repairs, I wouldnt use it on a new installation. there is nothing in the code precluding you from doing as such. Here is one available at most hardware stores.
http://solutions.3m.com/wps/portal/3...beQT6SM2Z6BCgl
Old 05-02-2011, 01:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The splice kits are good..used them at a large shopping center where we had a lot of underground wiring for parking lot lites and signage..
Sam
Old 05-03-2011, 02:14 AM
dinger's Avatar
You're going to miss them night-crawlers when fishing season opens.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 05-03-2011, 10:08 AM
302 Z28's Avatar
The splice kits when used properly will provide a water tight connection suitable for direct burial. In industry they are used all the time.
Vince
Question on wire size for Holley electric choke grobb284 Electrical 5 04-13-2009 03:42 PM
Help me wire my ELECTRIC FANS! DarknessSpawned Electrical 8 12-11-2008 10:43 AM
Fuel pump, electric choke and windsheild wipers on same wire sexypizzaman Engine 8 06-05-2008 08:23 PM
Electric Choke Wire GCD1962 Electrical 4 08-18-2007 09:25 PM
OEM electric fan wire colors sedan_dad Electrical 0 06-12-2002 03:26 AM
