Need Cam Advice, 355 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 03:56 PM
rac43's Avatar
I have posted questions before about my 355 but now I'm tired of trying to make more HP with what I have.
Current, 355, 76 #10 truck casting.
Bored .30 with forged crank
Speedpro flattops,
Edelbrock RPM intake and 650 Edelbrock Thunder carb.
882 heads and a GM 222/222 cam,
turbo 350 with 2500 stall,
HEI ignition,
3:73 rear
1 5/8" headers to 3 1/2 collector
Dyno's at 223HP, 276Torque ( sucks). Want to put on Aluminum Heads, 200cc runners, 64cc chambers.
Considering a XE274(230/236@50) or a XE262 cam. Want to stay under 10.5-1 and run on pump gas. Weekend warrior T-Bucket. Cam advise please, thanks
Old 08-01-2006, 08:17 PM
firestone's Avatar
http://teamrfc.gospelcom.net
How much money do you have to spend on a set of heads. The more money you have the more hp you can make. With the xw274h cam I would try to stick closer to a 180cc head though.
Adam
Old 08-02-2006, 08:46 AM
Mustangsaly's Avatar
is the Dyno #s RWHP ? just curious.........
Mustangsaly
Old 08-02-2006, 08:52 AM
rac43's Avatar
Yes, Dyno numbers are RWHP. We figure you can add about 30-35% with auto trans for flywheel HP. 35% gives 292 flywheel HP. Still way under what I want.
Old 08-02-2006, 09:01 AM
rac43's Avatar
Adam
Hi Adam and thanks. I can spend up to about 1K on heads. I have looked hard at the Aerohead Racing Dart heads for $700 but even with good recomendation from Chevyhighperformance they seem too close to what I have now. With my flat top pistons and Aluminum 64cc, 180cc runner heads, what do you think my compression would be? Also, can you tell me why you advise against the 200cc runners with my soon to be setup?
Old 08-02-2006, 09:22 AM
firestone's Avatar
Your compression should be right around 10:1. The reason that I recommend the 180 runners is to better match your cam. The 180 heads are better suited for the power range of where you cam is going to be making power. Going with a 200cc head would not be the end of the world, and it would probably make a little more top end power, but I would still recommend the 180's. As far as which head, for $1000, the best I know of is the trick flows.
Here is a trick flow 175cc head, $969 for an assembeled set. These would work well with the xe274h
http://store.summitracing.com/partde...5&autoview=sku
These heads have a 56cc chamber which would take your compression to around 11.3:1 which would probably be too much unless you got different pistons.
If you were willing to try the xe286h (240 246 @.050 duration @.050 .507 .510 lift), that cam would match the 195cc trick flows very well, that combo would make quite a bit more hp, and being in a t bucket, I think you could get away with the 2500 stall. They have a 62cc chamber which would put the motor around 10.5:1 with the flat tops.
Old 08-02-2006, 09:50 AM
Speedpro flattops,
HEI ignition,
3:73 rear
2 1/2" headers
What were the dyno numbers at the various rpm's? Is your throttle opening all the way up? Is 2-1/2" the primary tube size? If I make a similar engine in EA3.2 I get:
RPMиииииииииии1500ииии2000ииии2500ииии3000ииии3500 ииии4000ииии4500ииии5000ииии5500ииии6000
Brake_Tqииииии269иииии293иииии311иииии329иииии338и ииии338иииии326иииии293иииии245иииии193
Brake_HPииииии76.9ииии112иииии148иииии188иииии225и ииии258иииии280иииии279иииии256иииии220
Exh_Presииииии.1ииииии.1ииииии.3ииииии.4ииииии.6ии ииии.9ииииии1.1иииии1.3иииии1.4иииии1.5
Int_Vacuumииии0.0иииии.1ииииии.2ииииии.3ииииии.4ии ииии.6ииииии.7ииииии.9ииииии1.0иииии1.0
Vol_Eff_%иииии68.4ииии71.5ииии76.3ииии81.6ииии85.8 ииии88.6ииии89.9ииии88.3ииии84.4ииии80.0
Actual_CFMииии113иииии158иииии211иииии271иииии332и ииии392иииии447иииии488иииии513иииии531
Fuel_Flowиииии41.4ииии57.8ииии77.1ииии99.0ииии121и ииии143иииии164иииии178иииии188иииии194
A/F_Mix_Qalиии93.4ииии97.1ииии99.8ииии100.0иии100.0и ии100.0иии100.0иии100.0иии100.0иии100.0
BSFCииииииииии.539ииии.517ииии.521ииии.527ииии.539 ииии.556ииии.585ииии.639ииии.732ииии.880
BSACииииииииии6.763иии6.491иии6.531иии6.615иии6.76 2иии6.972иии7.336иии8.014иии9.177иии11.041
Friction_HPиии13ииииии21ииииии31ииииии44ииииии59ии ииии78ииииии102иииии132иииии169иииии210
Mach_#ииииииии.147ииии.195ииии.244ииии.293ииии.342 ииии.391ииии.440ииии.489ииии.537ииии.586
Piston_Spdииии870иииии1160ииии1450ииии1740ииии2030 ииии2320ииии2610ииии2900ииии3190ииии3480
Piston_Gsиииии145иииии258иииии403иииии581иииии790и ииии1032ииии1306ииии1613ииии1952ииии2323
Overlap_%VEиии-1.7ииии-1.7ииии-1.3ииии-.8иииии-.6иииии-.5иииии-.5иииии-.5иииии-.5иииии-.5
Int_AvgVelииии85ииииии113иииии142иииии170иииии198и ииии226иииии255иииии283иииии311иииии340
In_InertiaPrsи.0ииииии.2ииииии.6ииииии1.1иииии1.6и ииии1.9иииии2.1иииии2.2иииии2.0иииии1.9
In_ResTunPrsии0.0иииии0.0иииии0.0иииии0.0иииии0.0и ииии0.0иииии0.0иииии0.0иииии0.0иииии0.0
Ex_AvgVelиииии81ииииии109иииии136иииии163иииии190и ииии217иииии244иииии272иииии299иииии326
ExTun_Prsиииии.7ииииии1.3иииии1.2иииии.3ииииии-.2иииии-.6иииии-.7иииии-.8иииии-.7иииии-.5
Old 08-02-2006, 10:35 AM
have you looked at the 350 & 355 dyno #s on these combos http://ryanscarpage.50megs.com/combos1.html ?
lots of 350 & 355s with different head combos showing different HP #s, and aftermarket heads and showin GM stock casting Head #s including the Vortec Head. plus different cams with all head combos. really Good place to start.
Mustangsaly
Old 08-02-2006, 11:46 AM
rac43's Avatar
Took it up to 5K RPM under full throttle. Headers are 1 5/8 out of manifold then to a 3.5 collector.
HP at diff RPMS were as follows:
2600-90
2800-125
3000-145
3200-160
3400-175
3600-185
3800-197
4000-206
4200-212
4400-216
4600-218
4800-218
5000-223
No loss of power as RPM increases but very min gain from 3800 to 5000
Old 08-02-2006, 11:53 AM
rac43's Avatar
Mustangsaly
Yes I have spent hours reading the combos on that site. nothing reaaly matches what I want to do and lots of the combos are 60's 70's 355 setups.
Old 08-02-2006, 01:49 PM
What is it that you really want to do?
2-1/2" primary tubes would seem to be about a 7 tube size error, according to Ed Henniman. Something in the 1-5/8" range with an appropriately sized collector would make a remarkable difference in your performance. We had a motor similar to yours in a 64 Nova with 1-5/8" headers and it made 260 rwhp with a 2-bbl carb.
Old 08-02-2006, 02:32 PM
rac43's Avatar
Hi, my mistake. I just went out and mesured my headers and the tubes are 1 5/8" and collector is 3 1/2. Don't know where I got that 2 1/2 number????
Thanks
Old 08-02-2006, 03:18 PM
Hi Rac,
I kinda have the same problem as you.
I have a 357 SBC .30 over
Forged pistons
6.0 rods
Lunati roller cam and lifters 290 advertised duration 248 @ .050...555 lift
Roller rockers 1.6
Dart 215 pro1 aluminum heads
Demon 750
Airgap intake
Transmission 700R4
MSD ready to run dist and 6AL ignition box
373 rear gears
2800 stall
Dyno in at 302 RWHP
I too expected more (400 at the least)......I think my problem are that my heads are to big for the combo....I should have gone with the AFR190...
I kick myself for not doing the right thing...
You should listen to these guys they know what they are talking about.
Oh well live and learn I will just have to save up another $1200.00 and go for the AFR190......
Old 08-02-2006, 03:46 PM
rac43's Avatar
Originally Posted by 65Guera
Hi Rac,
Forged pistons
6.0 rods
Roller rockers 1.6
Demon 750
Airgap intake
Transmission 700R4
373 rear gears
2800 stall
Dyno in at 302 RWHP
Soory you are having problems with those heads. After reading here and a lot of other places, a 180cc will work a lot better for me and thanks to Firestone for his advise.
Old 08-02-2006, 05:03 PM
what CR is your 355 now ? man I would think theres some aftermarket head and cam that would bring your motor into the 400hp range, ( even some thing from ryans page) what is the problem , is your CR is to high with most aftermarket heads ? I think AFRs have some 76cc heads, others prob do too ( I might be wrong ), I know I seen someone made a vortec head that was 68cc, I just seen it on this engine forum. you might ask around. do you need a 68cc 70cc to 76cc head to keep your cr in pump gas range ? cause I like some of the 355 combos. my brother and I are planing on the forged 450hp combo, it was combo 12 and 13 and 14.
Mustangsaly
355 cam ray bob Engine 2 02-09-2006 07:33 PM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
HELP cam, intake, carb 64 nova Engine 9 07-12-2005 10:39 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
