Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need cam for mud truck
Old 07-12-2009, 09:21 PM
tuneup427 tuneup427 is offline
comp web sight suggest that you would use a 2200 stall converter with that cam. I would think that you would have a lot more power that you say you do. Did you install it straight up. (stock timing marks). You might want to double check your cam timing. Those cams run pretty well at 4 degrees advanced if I remember right. Maybe some one else will remember for sure.
