Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need cam for mud truck
Old 07-13-2009, 10:26 AM
inquiring_mind2's Avatar
inquiring_mind2 inquiring_mind2 is offline
a shade tree mechanic
no you will need to get a different carrier. the carrier you have is probably stock and you will need something better. the stock carrier will probably on handle gears up to 456 If I was you I would run a full spool. Here are a couple of numbers you can call to check on the gears Randy's Ring and Pinion 1 877 349 1369 and west coast Differentials 1 800 446 0950.... They may also have full spools but I don't know
