Need Cam Specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2012, 04:13 PM
Need Cam Specs
Have a Chet Herbert Cam #'s are B6K114 and 139536 can't find anywhere. Hoping someone has an old cam book. Thanks
Old 01-07-2012, 08:35 PM
THE BIG AL's Avatar
SSR Engines & carburation
C: Chevrolet
B: BBC
6K : Cam grind number Solid roller
114 : means it was special ground on 114 lobe center. (mostly done for NOS specific cams)
Cam Grind Type:MECHANICAL ROLLER CAMS
Application: CHEVROLET V8 67-93 396-402-427-454
Block Size: BB
Engine Make: Chevrolet (Chevy)
# Of Cylinders: 8
Manufactured In Year: 67 - 93
Cubic Inch Size / Volume: 396-402-427-454
Additional Qualifier:
Brand Code: Herbert Performance Cams
Cam Only Part #: CB6K
Dur Int-Exh: 285/290
Dur @ .050 Int-Exh: 245/255
Lift 1.5 - 1.5 Int/Exh:
Lift 1.6 -1.6 Int/Exh:
Lift 1.7 -1.7 Int/Exh: 665/680
Lobe Center: 106
Valve Lash: .018-.020
RPM Range: 2500-6800
Al
Cam specs please Disesl Engine 5 11-21-2010 09:09 PM
cam specs srx_700 Engine 3 04-19-2010 06:15 AM
Need Specs? Idriveatincan Suspension - Brakes - Steering 2 10-18-2005 11:26 PM
Cam Specs. Everett II Engine 4 09-13-2005 04:32 PM
'68 gmc, 427 specs Chevy Thunder2 Hotrodders' Lounge 4 03-18-2004 08:41 AM
