Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need cam suggestions for my 383 build
Old 12-23-2004, 03:58 PM
firestone's Avatar
firestone firestone is offline
http://teamrfc.gospelcom.net
I assume that you are not going roller because of the price, that is ok, it is something you can upgrade in the future if you want. I agree with the use of a single pattern cam with the AFR heads. If you are set on a solid cam, I would use the 282S (236 236 @.050, .495 .495 lift 2000-6000 RPM). If you use a hyd cam, I would go with the 280H( 230 230 @.050, .480 .480 lift 2000-6000 RPM). Both of these cams would work really well, and even better with a set of 1.6 rockers, which I would suggest.
Good luck
Adam
