need car stereo help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2004, 04:57 PM
bandit1's Avatar
New Member
i listen to 80,s metal you know poison warrant kix and i need some advice on what stereo and speakers to use the audiovox stereo and speakersi have now distort when you crank the volume past 3/4
Old 01-01-2004, 06:39 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
sparkomatic has always served me well.
Old 01-01-2004, 06:46 PM
poncho62's Avatar
Wiki Edits: 5
That crap sounds the same, no matter what system and speakers you have....it sounds....BAD.
kidding.........to each their own.
Ontario Rodders
Old 01-01-2004, 07:51 PM
345coupe's Avatar
Re: need car stereo help
Speakers may not be your answer. You would be better off getting a bigger amp. If your speakers are rated to handle 100 watts of power, get an amp that puts out more than that. The amp will still be producine a clean sine wave output and you'll be in less danger of blowing the speaker. A 100 watt stereo will not sound twice as loud as a 50 watt stereo. What it will do is put cleaner power (sine wave) to the speaker, letting you drive the speaker to its maximum potential. A 50 watt stereo for example, will "clip" the sine wave to more of a square wave shape. What does that mean? Distortion. Heat. Fried voice coils. Blown speakers.
Too much bass going through a small, full range speaker will give you intermodulation distortion. A single speaker cone has trouble reproducing bass and treble sounds clearly at the same time. Go for 2-way or 3-way speakers.
You'll blow a speaker rated at 100 watts faster with a 10 watt amp than you will with a 500 watt amp.
