need to change carb fuel application - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 02:31 AM
I will be changing my car over to methanol in the winter to come to save money for fuel and to build serious hp. however I dont want to spend a $1000 on a new carb. so how hard is it to take a 4150 series 950 cfm holley or something comparable and convert it over to use methanol?
Old 09-17-2010, 03:02 AM
ericnova72's Avatar
More for Less Racer
Its a lot of work, it isn't just a simple jet change. Boosters, metering blocks(emulsion wells are different, and have different siphon breaks), air bleeds and fuel restricters for idle feed and power valve channels all need to be changed. Accelerator pump diaphrams and gaskets/o-rings need to be alky compatable, needle and seats need to be alky versions, pump shooter size needs to be increased. By the time you are done you are close to 85% or more in cost of the dedicated alky carb, plus you need the knowledge to do it, and special equipment to change the boosters.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Fuel disappearing from fuel line at carb K and K Engine 24 08-14-2010 04:30 PM
No Fuel Getting to Carb newdad1 Engine 7 07-07-2009 06:43 PM
fuel pump failed during carb overhaul?! pcoghlan Engine 5 02-22-2009 09:44 AM
fuel pump running but no gas to carb? dhomsey Engine 2 07-30-2008 01:16 PM
