We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-10-2004, 06:59 PM
V ate Chevette's Avatar
V ate Chevette V ate Chevette is offline
New Member
Need cheap short Chevy water pump
I was wondering if any of you smart guys out there would know if there is an aluminum short small block Chevy water pump available at local discount part stores. Did I say cheap! I need an application,model and year. It needs to have passenger side lower hose discharge. I saw a 70 Corvette pump and it looked great, I don't need mounting lugs. It's for my V8 Chevette project. Thanks for help!
Old 11-10-2004, 07:28 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
I believe any SBC prior to '68 had the short water pump. You may not find an aluminum model in local stores. Probably be cast.
Old 11-10-2004, 09:20 PM
HemmiGremmie's Avatar
HemmiGremmie HemmiGremmie is offline
Not sure about the water pump, but have you ever drivin the Cvette with a V8 in it?
I had one with a nice built 350, turbo 350 tranny about 3 years ago and it flat flew! Scary quick. I broke 3 regular Cvette rear ends, so Id get an S-10 rear and do a swap.
Ive got a pic in my gallery and more to add that I just found. Take a look. It was a fun ride. HG
p.s. Nice job your doing on yours so far.
<<< Click on my Gremlin avatar to the left there to see my pics.
Holy Cow! I just seen that your from Columbus! I live dwn here in Chillicothe about 45 minutes away. I'll have to come see it sometime.
I was built with the body of a God! To bad it was buddah.
http://www.hotrodders.com/forum/jou...&journalid=2415
Old 11-10-2004, 09:24 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Stewart Pumps makes one for $60.
Old 11-11-2004, 11:32 AM
New Member
Thanks for trying ,I knew it would be a long shot for an aluminum pump. I'll go with the Corvette pump,it's only $24 for a new one -no core. Hemi, did you have all the same problems I've had with the build?
Old 11-11-2004, 01:10 PM
Luckily when I got mine, I was only going to buy the engine and ended up dealing him outta the whole car.
It had headers and looked like a factory fit. He done a great job. So I had to do basically nothing. There was some V8 chevette swap sites online some time ago, but I'll have to try and remember were.
There a blast when there done though. HG
Old 11-11-2004, 03:22 PM
New Member
I've seen quite afew of those sites,there pretty incomplete with sketchy details
Old 11-11-2004, 04:11 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
1BAD80's barnstar
Wiki editor
Last wiki edit: How to adjust valves
Wiki Edits: 2
The vette pump use's a 3/4" bearing instead of the 5/8" for better bearing life.
Luv the smell of NITRO in the morning.
Old 11-11-2004, 05:04 PM
camaroman7d's Avatar
camaroman7d camaroman7d is online now
Not only the bearing size is different for the Corvette pump. The Corvette pump is not a true short water pump. Most people will ague this point and most people don't know. I will have to look up the measurements I have been there and done that.
There is the short water pump, the long water pump and the Corvette water pump. The Vette pump is not as short as the short pump and not as long as the long water pump.
You might want to hit e-bay, there are a ton of aluminum water pumps for sale on there. You can get one cheap (sometimes cheap is not always good).
If you are starting from scratch the Vette pump might work for you, just don't be surprised when/if none of the pulleys line up.
Royce
Old 11-11-2004, 05:10 PM
ALASKAN's Avatar
ALASKAN ALASKAN is offline
waterpump
he guy
try e-bay--they have pictures of over 200 chevy water pumps---mostly all short...and of any size and shape you can think of or need....most cost between 25-125 dollars-nd for that you get very great pumps....
i just bought a hard to find one for my stroker hot rod suburban for 46 bucks with shipping.....and even chromed-with the size water outlet i was looking for....if you do not have acess to the bay---try a friend who does....good luck
alaskan
Old 11-11-2004, 06:14 PM
1BAD80's Avatar
1BAD80's barnstar
Wiki editor
Wiki Edits: 2
The pumps made by GM are the same overall size with different bearing size's, same castings used.
I have both types of pumps and the overall size is the same.
Don't forget the difference in the pulley hole size and the clutch fan will have to fit the 3/4" nose.
Alaskian has a beautiful truck that one must see.
Soooo much work and detail.
Old 11-11-2004, 11:05 PM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
I have moved the flange on the shaft to get the pullys to line up.
Troy
Old 11-12-2004, 10:53 AM
New Member
Thanks...Ebay great idea! The short pump diamentions are 5 7/8" and the long pump is 7 1/4. I don't want an inbetween like Corvette. I guess it just sounds too much like Chevette !
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
