Originally Posted by newdad1
Hello,
I have a chevy 350 that I am helping my brother rebuild. We put the crankshaft and cam in yesterday. We are getting ready to install the rings on the pistons. The motor is going in a 71 camaro that will see mostly street use. He just got it back from the machine shop, everything has been balanced. The pistons are SilvOlite hypereutectics @ 10:1 compression with 4 valve reliefs cut in the top. The rings are from Sealed Power p/n e-251k 40; 2m-139-040. The top ring is chrome moly and for high performance use they recommend gapping the top ring at .022 inch. This is all the information they give us as far as the rings are concerned. What do I gap the second ring at(second from top) , and what do I gap the 2 side rails that go with the oil expanderspacer at?
Thanks, RJD
KB/UEM pistons have a specific ring end gap factor that is larger than typical.
Follow the KB UEM directions for your KB UEM pistons to the letter.
The ring end gap factor directions for KB silvolite are
HERE
Do not second guess their larger than typical top ring end gap requirement.
These piston are made of a proprietory aluminum alloy (they are different)
They know that they are doing.
Your motor will not huff or smoke or have less compression or power what ever else you fear by using their recomended larger top ring end gaps. But if you don't follow their specific direction and insist on using typical cast piston ring end gaps (.016 to .020") you'll be doing it all over again. See the pictures.
The second ring gap is not near so critical. Some builders make the second ring end gap sightly bigger, some make it slightly smaller.
http://kb-silvolite.com
