Need diagram for a 90 chevy z71 700r - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 12:15 AM
I need a diagram for a 90 chevy z71 700r trans
Old 08-21-2011, 01:05 AM
Overdriv's Avatar
You need to be more specific in your request for help. Electrical diagram? Hydrualic diagram? A search of this forum will probably find your answer as the 700R4 has been discussed a LOT.
Old 08-21-2011, 03:41 AM
trans
diagram of clutch an valve body assembly
Old 08-21-2011, 04:06 AM
trans
well c I have a 90 chevy z71 an it shifts from 1st too 2nd fine but when it goes too go too 3 its like it goes too neutral till it slows down a lil an it drops back down to 2nd u speed back up an it does tha same thing tha truck was set up for a couple of years an trans got a lil water n it I changed tha filter an fluid but didnt help so I wanna tare it down an clean everything up an try that but Ive never tore an auto trans down so I would like too have a diagram too go by too put it back together
Old 08-21-2011, 04:19 AM
Overdriv's Avatar
You will need this and this.
You need a few special tools also.
Old 08-21-2011, 07:58 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
dilla69,
Welcome to Hotrodders.com
I edited the thread title. Please place more information in the title than "trans" .. more info helps the membership know what your question subject is.
You need a ATSG manual to rebuild this 4L60 transmission.
If 3rd gear free-wheels (neutral feeling) , you have a 3-4 clutch burned up. A proper rebuild is needed along with converter replacement.
wiring diagram for 75 chevy C10 PU DOUBLEDICK Electrical 11 05-28-2007 02:45 AM
HOW TO MAKE 700R ELECTRONIC TRANS WORK IN 59 Chevy pick up hexx Transmission - Rearend 4 02-11-2007 01:31 PM
700R in a 1969 Chevy Howie1 Transmission - Rearend 8 01-13-2007 04:07 PM
wiring diagram for 87 chevy DDBrowneyesDD Electrical 3 07-18-2005 10:26 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
