need diff id help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 07:47 PM
need diff id help
hello out there, wondering if i could get some help on identifying a gm rearend, its a 10 bolt center section, casting number is 3725899 GM10 and the other is B178 or 9 last number is hard to read, the housing has a drain plug, which some other forums say it could be a 57 chevy because of the plug. and there is also a stamping on the housing of an "S". if that helps. any info is appreciated. thanks
Old 03-29-2007, 04:49 AM
re:need diff id help
Take a look on the axle tubes for letters and numbers. They might be on the pass. side or driver side. What are those letters and numbers. They should be close to the carrier. But can be anywhere on the tube.
Need a little more Diff. help??? gwstang Transmission - Rearend 5 11-15-2005 08:37 AM
used diff gears rumpity_z28 Transmission - Rearend 3 06-05-2005 01:38 PM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 08:45 AM
ford 8 3/4 diff Snake Eater Transmission - Rearend 1 11-13-2004 12:07 PM
How to mount this diff Neophyte Transmission - Rearend 9 07-24-2004 04:39 AM
