Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need directions to repair chevy rearend
Old 02-16-2011, 04:07 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
You will need a dial indicator, Inch lb. torque wrench, ft. lb. torque wrench, Large brass mallot, Large pry bar. Hand tools etc. A couple years of experience.
A install kit for ring+pinion. A stack of bearing shims. All bearings/seals.
Rear end work is not for the novice
