Need to do multiple hook-ups - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2008, 08:46 PM
chevy3600's Avatar
http://community.webshots.com/
I am ready to make all the usual hookups to the engine (350 crate w/edlebrock carb, HEI distributor, and booster brakes) and need some information on where to hook-up:
1. the vacuum from the brake booster
2. the vacuum from the distributor
3. the oil sender
4. the temp sender
5. bat. to dist.
http://good-times.webshots.com/photo...99708909XxCamn
Old 01-28-2008, 08:32 AM
MI2600's Avatar
Member# 3287
1. Vacuum for the brake booster usually comes off the port on the intake manifold behind the carb.
2. Vacuum for the distributor comes from the front of the carb. There are two smaller ports on the carb, one a little higher than the other. The lower one is full manifold vacuum. The other is "ported" vacuum. I usually go with the lower one.
3. Oil pressure sensor for an electric gauge is behind the intake on the block.
4. Temperature sensor is normally in one of the heads, usually the driver side. You should find a plug in each head, adjacent the spark plugs. Remove the plug, insert sensor.
5. There's not direct connection between the battery and the distributor. Main battery power goes to the starter.
Old 01-28-2008, 11:30 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Voltage to the distributer comes from the ignition switch...there should be a wire coming off of your harness in the area near the distributer for that.
Old 01-28-2008, 01:36 PM
chevy3600's Avatar
Thanks guys. I always thought the oil pressure sensor to be where you said, on the block behind the intake. However there doesn't seem to be a plug there. I do see a plug about an inch and a half above the oil filter, driver's side; would that be it?
Also I don't see the plug for the temp sensor. I guess I'll find it sooner or later.
You say you use the lower port on the carb for the dist vacuum? What do you use the upper port for?
Old 01-28-2008, 02:08 PM
Look again ...
See the rear of the block ... where the bottom of the intake goes ... you should see 4 small holes where the end seals sit and one larger threaded hole for the oil pressure sending unit. It is 1/8 NPT
That's the one for the oil pressure sending unit.
Randy
Old 01-28-2008, 02:16 PM
Do you have a Vacuum gauge ?
I think every guy who messes with cars should own one.
The vacuum line should be run from a steady source of vacuum on the carburetor to the distributor ... and a vacuum gauge will allow you to determine which source is " full time vacuum " or not. Some sources of vacuum on the carburetter are only sources when the throttle is opened ... not when the engine is at idle. The other port can be plugged.
Old 01-28-2008, 02:48 PM
chevy3600's Avatar
EUREKA, I FOUND IT!!!
That old adage, "a picture is worth a thousand words" is certainly true here. Now I have to get me a vacuum gage.
When I buy the wiring should it come with temp and oil sensors?
Or should I go ahead and buy them now. I'm waiting on the cab to get back from the body shop.
Old 01-28-2008, 02:51 PM
MI2600's Avatar
Member# 3287
There is another oil pressure port above the filter, but I've had to use it. Most ignition harnesses have the oil pressure wire going to the top rear one.
If you don't have any plugs in your heads, you can get intake manifolds with a water port for the temperature sensor. Edelbrock springs to mind. The port's usually on the front, top driver's side.
Old 01-28-2008, 04:03 PM
Look at the front on the intake and see the larger opening NPT holes ... near the thermostat opening. That's where the temperature sending units go. I almost always use aftermarket gauges and sending units ...
Old 01-28-2008, 04:46 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I also used the port in the intake for the temp sensor. Used a T fitting for oil so I could run a mechanical and electric oil pressure gage. I used the port on the top by the distributer. I put the electric in the car and the mechanical under the hood, going to use the oil port above the filter for a oil pressure switch to kill the fuel pressure.
Old 01-28-2008, 05:04 PM
chevy3600's Avatar
Jake, I'm confused, you use the oil port above the filter for an oil pressure switch to kill the fuel pressure?
Old 01-28-2008, 06:58 PM
Not yet but I was going to see if I can get it to work. It should have enough pressure there to activate the switch.
Old 01-30-2008, 02:45 PM
A good many of the later V8 Chevy's have a pressure sensitive switch that can kill the ignition if pressure drops below a certain point. The first one I actually saw was on a IROC Z28 Camaro with the TPI unit. It is fairly common for rodders to use a T-fitting and run BOTH a sending unit for the oil pressure gauge and a " idiot light " also. The first time I did it was 1969 on my new (then ) 396/375 horsepower, 4 speed 1969 Super Sport Nova.
Old 01-31-2008, 04:57 AM
I don't use the computer in the car anymore, so if the motor cuts off I want to make sure the fuel pump stops as well. Should I get in an accident I don't want it to dump what fuel I have left in the tank on a hot motor.
Old 01-31-2008, 06:53 AM
chevy3600's Avatar
Has anyone used a three way fitting for the oil pressure guage, the idiot light, and the gas cutoff? If so how did that work?
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
CB Radios ChevelleSS_LS6 Hotrodders' Lounge 23 04-12-2005 06:34 PM
Generator hook ups jackfrost51 Electrical 3 05-07-2004 09:22 PM
intake/carb hook ups. help please montea Engine 11 03-16-2004 11:40 PM
gimmie the low down on multiple carbs bigwildgrin Engine 11 05-13-2003 06:46 PM
