Need a doner column reccomendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2012, 11:55 PM
Elevinpointsixtoone's Avatar
Howdy, I am going to build up a stub column for Model A Tudor. Can you guys toss out some good doner tilt columns I can go hunt down? I'm wanting to avoid the modern look with the integrated key and plastic fugly clamshell housing. I'm just not sure where to find a simple tube style column with tilt. Pickups? I dunno.....
Thanks,
Dave
Old 03-21-2012, 04:27 AM
Wiki Edits: 31
1970's GM van, but by the time you find 1 and clean it up, you'll be out $200 or so, there are $250 aftermarkets available if you shop around
Old 03-21-2012, 11:54 AM
After posting I found some info that said basically the same thing: GM or Chevy van tilt. How about Ford vans? I think I've seen way more Econolines than Chevy vans over the years. I can convert the plug...no biggy there (besides I'm using a Mopar harness :-0). I have a old Mustang II tilt column and was going to just cut off and shape all the modern looking outer stuff but then I realized its missing the turn signal electrics etc....so back to hunting.
stall speed reccomendation powerrodsmike Transmission - Rearend 6 07-21-2009 08:28 PM
Reccomendation between two cams. eric32 Engine 21 11-29-2008 09:47 AM
Carb Reccomendation Please 1985fiero Engine 4 09-29-2005 06:55 AM
Reccomendation for gauges? dinger Hotrodding Basics 10 04-24-2005 03:52 PM
web site reccomendation nzsimon Hotrodders' Lounge 0 10-02-2001 02:33 AM
