need drag tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2010, 08:20 PM
bigdog7373's Avatar
Of course it's fast
need drag tires
i don't know what size rear drag tires to get for my firebird. The tires that are currently on the car are 215 65 15. I don't want to have to buy new rims and they need to fit in the stock wheel wells. Thanks in advance for your help...
Old 05-15-2010, 06:03 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Tell the tire shop or wherever you are going to get the slicks, Tell them the size you have on it now, Let them match a set to your tire size. They can get pretty close if not right on your size.JMO
Cole
Old 05-15-2010, 06:43 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
You need to know your rim width to maximize the tire size. By using different wheels that will let you get the most tire width within the wheel wells, taking back spacing into consideration.
M&H has a 215/65/15 Street & Strip DOT tire for use on a 6" wide wheel they also have it in a 235/65/15 for a 6.5" wheel, then there is a G60 15 for a 7" wheel.
Old 05-15-2010, 09:28 AM
bigdog7373's Avatar
Of course it's fast
how do i know how wide the rim is?
Old 05-15-2010, 09:55 AM
Art Deco's Avatar
What year Firebird? Does it have the OE wheels?
Old 05-15-2010, 08:16 PM
bigdog7373's Avatar
Of course it's fast
It's a 78 firebird esprit. I don't know if they are stock wheels [IMG]101_1780[/IMG]
Old 05-16-2010, 07:46 AM
hm put you some 15-8.5's on the back and go with some 28-10.5-15M/T et's, if you got enuf motor 4 them!
Old 05-16-2010, 01:43 PM
bigdog7373's Avatar
Of course it's fast
What sizes slicks will fit on 15x10 wheels?
bigdog7373's Avatar
Of course it's fast
Old 05-16-2010, 02:21 PM
a 28-10.5-15 will fit the 15/10 rim!
Old 05-17-2010, 05:57 PM
Art Deco's Avatar
Keep in mind the wheel width should be measured from the inside lip where the tire bead seats.
I'm with gofastz on this one.
Also your rear gear ratio can play into which overall diameter to use.
I once put a 26" tire on a Challenger with 3.91's and I was sorry at the end of the track.
I tested my motor at the drag strip yesterday! DENCOUCH Engine 14 08-17-2009 09:18 AM
Return to drag racing. Ronnie C Introduce Yourself 4 03-14-2008 07:41 AM
Interesting theory about wide tires ChevyThunder Hotrodders' Lounge 8 10-24-2006 05:27 AM
Rear Drag Shocks on a Street Car? JohnTN Suspension - Brakes - Steering 2 08-09-2005 04:25 PM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
