-   -   need a drip rail for 1931 Graham are Fords the same ? (http://www.hotrodders.com/forum/need-drip-rail-1931-graham-fords-same-195469.html)
1931 graham rod 03-30-2011 08:13 AM
:) Hello Everyone,
I am looking for a drip rail that goes on the right side of my 1931 Graham Prosperity 6 it is 5 ft. 6 in. long and has about a 3 in. bow to it. It comes in 2 peices you nail the first peice on and i beleive snap the rail on after. So i was wondering if Model A Fords had the same supplier years ago and would know where i can find this drip rail. PLEASE HELP !!!!!! :)
Footstomper 04-05-2011 11:10 AM
1931 Graham drip rail
http://www.geneshotrodparts.com/
I think he is still out there. I had to replace my right side of my 40 ford coupe, rust near the decklid missing 7 inches. I just replace all of that side. It was in the rain on pole barn side, the other was fine.
I got inside and carefully with a circle cutoff/hammer and chisle without distorting the outside. You only need just that the drip rail can slide from outside. I have never seen a 31 Graham. Gene's would probably would start with a machine with a straight drip rail. I would think your model would be better that way. Maybe just take the top off for you project, when you could easy if you understood. If it is more like a forty ford. If you send me a photo of your Graham. Grahams are really neat, if it is like a box, all you have to heat the cut/pie/corners. Use alot of clamps, clean joints or sandblast inside and use Epoxy after tacking with a mig welder. If you have curves on the rails, you will have to heat as matching with the seams. That's how I did it on my forty ford.
Good luck!
Footstomper
